Voltage light
Llamaguy
PostPosted: Wed Jun 15, 2005 1:50 am    Post subject: Voltage light Reply with quote
I replaced the alternator a few months back; the last week or two the light has been coming on dimmly, but almost only at night. It glows brighter when I turn on lights, brights, ac or heater. I try testing it during the day, but i can't get the light to come on, even with everything turned on. It's only putting out about 12.5V anyways, which is lower than when I first put it in.
is this regulator or diode problems?
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
PostPosted: Wed Jun 15, 2005 4:43 am    Post subject: Reply with quote
Could be a short in the wiring loading down the alternator, or a bad connection, or a bad battery, or a loose drive belt, or a bad alternator.
Gram
PostPosted: Wed Jun 15, 2005 9:46 am    Post subject: Reply with quote
The voltage drops on my 924 when the belt gets loose..goes back up near 14V when I tighten it.
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
PostPosted: Wed Jun 15, 2005 10:45 am    Post subject: Reply with quote
Start by cleaning all the connections including the ones at the starter and battery. Do both the + and - connections.
Codyboy
PostPosted: Wed Jun 15, 2005 11:05 am    Post subject: Reply with quote
i had the same problem mine turned out to be a shitty ground
Go hard or go home
augidog
PostPosted: Wed Jun 15, 2005 11:30 am    Post subject: Reply with quote
I agree -check the ground
Run a temp and see if it goes away
Min
PostPosted: Wed Jun 15, 2005 1:08 pm    Post subject: Reply with quote
check the voltage drop between the alternator body and the battery.
Min
PostPosted: Thu Jun 16, 2005 6:13 pm    Post subject: Reply with quote
I have a heavy guage earth cable attached from the engine to the body of the alternator.
When I found it had come off once I had the same problems you describe.
