joe
Posted: Fri Jun 17, 2005 11:19 am Post subject: Injector holder source |
Would anyone be able to tell me where I might find an injector holder for a 80 931?
Is it a porsche specific part or could I get one from something else?
thank you |
Paul924
Joined: 19 Apr 2003 Posts: 73 Location: Minneapolis, MN / Ames, IA
MunkPuppy
Joined: 02 Jul 2003 Posts: 419 Location: New Westminster, B.C., Canada
Posted: Fri Jun 17, 2005 1:01 pm Post subject: |
sadly, it is a porsche specific part. I don't remember the cost, but they aren't too much.
Paul, the Turbo (931) has screw-in injector bungs, to keep the injectors from popping out under boost. The non-Turbo models have only O-rings because obviously there is no boost, and the intake vacuum holds them in place. _________________ '80 931 FOR SALE
-Anton Szandor LaVey |
Posted: Fri Jun 17, 2005 6:31 pm Post subject: |
I am not sure, VW may have something you can use since they sold cars with the G40 and G60 G-Lader (supercharger). The injector inserts used on some normally aspired fuel injected VWs were teh same as those used on the 924, so maybe they used some of the same (or a compatible) inserts.
You could try taking out one of your surviving one/s inserts, and going to your local VW dealer to see if they have something that matches up. |
numbbers
Posted: Sat Jun 18, 2005 9:55 am Post subject: |
Are you guys talking the plastic injector adapters? _________________ 1980 924 Turbo |
