79 fuel pump cut off switch??
bryan13
PostPosted: Wed Jun 15, 2005 3:35 am    Post subject: 79 fuel pump cut off switch?? Reply with quote
I bought a 79 924 that took a 14 inch drop off the highway cracking the oil pan, thrashing the lower cross member and bending the passengerside control arm and sway bar link. I am still looking for the sway arm link and control arm if someone has either to get rid of. Now on to my question, does the porsche have a cut off switch like the fords do? I was planning on direct wiring it to a battery to see if it kicks on, but there are several wires and I dont know which ones to use.
gohim
PostPosted: Wed Jun 15, 2005 4:40 am    Post subject: Reply with quote
No, the 924 does not have an fuel-cutoff circuit as later cars do (required by law on later/newer) cars. The 924 design and production is too old, and the law was not in effect.
Post an ad in the Wanted/For Sale Section for the parts that you need.
