Pierburg fuel pump- latest price
augidog
PostPosted: Wed Jun 08, 2005 11:12 am    Post subject: Pierburg fuel pump- latest price Reply with quote
Pierburg pump. www.alleuro.com
AllEuro's price $167.00.
I just ordered one. My retailer quoted me $245. for the OEM
I hope it kills my Gremlin.
PostPosted: Wed Jun 08, 2005 12:27 pm    Post subject: Reply with quote
Not bad, the price came back down some.. It was $189 at AllEuro when I was in need and I missed a chance to get it somewhere else at $144 ( http://www.autohausaz.com/catalog/lookup_parts.cfm?VehicleID=1263305&CFID=2746738&CFToken=94088097&partnum=91160810202 ), ...but now I see autohausaz is only listing the OEM pump, and at $228.
http://www.924board.org/viewtopic.php?t=6123&postdays=0&postorder=asc&start=10
PostPosted: Wed Jun 08, 2005 2:30 pm    Post subject: Reply with quote
yup it was I thought no-way way to high almost 200.00
sna-dizzle not going there. Hope it gets you back to square.
Eturbo924
PostPosted: Fri Jun 10, 2005 2:21 am    Post subject: Reply with quote
I got one from them and the total with express ship was less than $200. I can tell you the pump is excellent quality and very quiet. I can not hear it when the car is running. Which is some thing I could not say about the pump it replaced. I was impressed with it.
Also it is much cheaper than the OEM part!
Eric
www.geocities.com/eturbo924
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast!
PostPosted: Fri Jun 10, 2005 3:56 pm    Post subject: Reply with quote
Whats goin on with the pump. did you get it in yet.
Eturbo924
PostPosted: Sat Jun 11, 2005 2:34 am    Post subject: Reply with quote
I got mine at Zims
The old pump was on its way out. Buzzing like crazy and intermittant sound. Same thing my 1980 did just before cashing in.
This one is excellent. Quiet and noted to be higher presure.
Also bolted right up. No need to use any special fittings.
1992 968
2003 C4S
Drive Fast!
PostPosted: Sat Jun 11, 2005 3:52 pm    Post subject: Reply with quote
Isnt it like a quite hum at first then when its pressurized or
something like in few seconds it gets
lower thats what mine does.
augidog
PostPosted: Mon Jun 13, 2005 3:42 am    Post subject: Reply with quote
Just like Eturbo924 said: Just bolted righted in ,no problem.
Nice pump.
All little performance gains for me ( new coil, pump),
but still not the Gremlin.
Next step--newer control module from a parts car.
Taking it in to the muffler shop to see if its just a certain RPM rattle.(fat chance)
After that--the dreaded oil pan removal and rod and bearing check.
Eturbo924
PostPosted: Mon Jun 13, 2005 5:33 am    Post subject: Reply with quote
Mine is basically silent when the car is on... well dround out by all the other sounds. Not like the stock unit which you can hear all the time.
1992 968
2003 C4S
Drive Fast!
augidog
PostPosted: Mon Jun 13, 2005 6:44 am    Post subject: Reply with quote
All my problems might be stemming from a bad gasket that connects the exhaust manifold to the straight pipe below the heat shield.
It looks to be separating and getting white (I’ve been looking for cracks).
The engine is extremely hot around this area now.
Maybe the lack of backpressure would account for my ping like symptoms under load that go away.
I wonder if the chatter I hear is the valve hitting from lack of backpressure.
It would be nice.
Maybe its header time.
