PaulW
Posted: Sat Jun 11, 2005 11:05 pm Post subject: Fuel problem |
My fuel pumps wont run,have replaced relay and checked pumps and all are working fine but pumps will not activate,any ideas as to what else it could be,pumps run fine if relay bipassed.
Paul |
Raceboy
Posted: Sat Jun 11, 2005 11:48 pm Post subject: |
If relay is in place and working, fuel pump shouldn't run unless engine is running. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Sun Jun 12, 2005 8:48 am Post subject: |
The fuel pump should run for a few seconds when you turn the key on.
I think it runs on some models while cranking the starter as well.
(this is from the starter circuit)
After that it will run only when the engine is running.
Ignition switch?? _________________ Porsche 924 1984 (UK import) NA
