alternator belt wont stop squeeling
alxch1n15
PostPosted: Sat Jun 11, 2005 8:43 am    Post subject: alternator belt wont stop squeeling Reply with quote
hey everyone, so after buying a new alternator belt, and putting it on and tensioning it, three times, it still squeals and heats up to the point where you cant touch it. i dont know if thats normal or not, but my fingers blister almost instantly after touching it, and thats after 2 minutes of driving. i dunno what the pbolem is, maybe worn alternator bushings?
any suggestions?
oh yeah, sorry if this has been covered before, i did some searching but there wasnt much info that i could find.
'81 924 n/a
augidog
PostPosted: Sat Jun 11, 2005 11:32 am    Post subject: Reply with quote
Something may be seized or on its way out.
Why did you replace it? Did it break?
Loosen the belt and see if everything will turn by hand.
PostPosted: Sat Jun 11, 2005 12:58 pm    Post subject: Reply with quote
Cast your eye over the pulleys and belt.
Does all the pulleys look parallell?
If the alternator bushes are worn the unit will look tilted towards the water pump and the belt will not look straight.
No amount of tensioning will correct this.
If the alternator has been put on too far forward (via a different mount) the belt will look wrong as well.
alxch1n15
PostPosted: Sat Jun 11, 2005 2:32 pm    Post subject: Reply with quote
hmm....the alt. looks straight, and the bar that i put up against it seemed straight. i had my dad help swing it out farther, so hopefully it will hold like that, everything turns by hand, so hopefully thats not the problem. the original belt, or one before the on i put on, was on its way out, it had a problem holding, and i decided replacing it was the easiest and probably only option.
'81 924 n/a
PostPosted: Sat Jun 11, 2005 3:47 pm    Post subject: Reply with quote
what shape do the rubber mounting bushings appear
to be in. they tear and get chunks tore out then sit
in the metal cup weird cause they cant take up the space
and you cant take up the slack. they ll go out of alignment next.
Hey smoothie can Nappa get alt mount bushings.
timstar92404
PostPosted: Sat Jun 11, 2005 5:40 pm    Post subject: Reply with quote
my belt squeels really loud too when the rpms are low....
and I have tensioned it many times .
there is something really wrong if it heats up....... don't think the belts are suppose to get hot......
78 924 sold.
85.5 944
PostPosted: Sun Jun 12, 2005 3:23 am    Post subject: Reply with quote
so whos gonna go to a nappa and find replacement
rubber bushings...
Smoothies probly knows if they can get them.
napa can get like oil drain plugs and belt tensioners
and other stuff...
PostPosted: Sun Jun 12, 2005 8:39 am    Post subject: Reply with quote
Also check the water pump and alternator turns freely, the bearings may be on the way out.
