fuel pressure regulator
alxch1n15
PostPosted: Sat Jun 11, 2005 12:39 am    Post subject: fuel pressure regulator Reply with quote
hey everyone,
so would i be able to change my fpr, im not sure what bar it is, to a 3.0 bar i had from my saab? will that cause any problems? as i recall, all it does is regulate the amount of fuel going into the engine, and a larger bar, such as the 3.0, will provide higher pressure, which will give better acceleration?
on the 1990 saab 900 n/a, they put the 3.0 bar fpr on to give better acceleration because it was too slow compared to the 900 turbo. i did that conversion, 3.0 onto the turbo, and it gave me better acceleration.
any ideas?
alex
'81 924 n/a
PostPosted: Sat Jun 11, 2005 12:59 am    Post subject: Reply with quote
That kind of change isn't applicable to the 924. Pressure regulation is integrated into the fuel distributor (haynes page 76, bottom-left). Also, your primary pressure should already be in the range of 5.4 to 6.0 bar.
PostPosted: Sat Jun 11, 2005 5:41 am    Post subject: Reply with quote
realy ? in the distributor ? then whats that aluminium part located under the coil there are two fuel lines leading to it...man i tought that is the fuel pressure regulator.
PostPosted: Sat Jun 11, 2005 6:31 am    Post subject: Reply with quote
The part under the coil is the control pressure regulator (aka "warm-up regulator" or WUR). System (aka primary) pressure's regulated at the fuel dist.
