A-arm and tie rod
MunkPuppy
PostPosted: Tue May 31, 2005 8:14 am    Post subject: A-arm and tie rod Reply with quote
got a couple questions.. now that Lizard is gone, I don't have the most readily available resources..
I'm hunting for an A-arm and tie-rod end so that I can replace them this weekend. I've been told that a VW Rabbit A-arm is a direct replacement, but the question of reinforcement has come up.
Are they actually the exact same A-arm as a Rabbit, or is it reinforced?
Will a 944 A-arm work, since I have the M471 suspension?
And what size ball-joint should I be using? I'm aware that they both bolt in. Can I just use the ball-joint and tie-rod pair from the same car?
TIA
Munk
'80 931 FOR SALE
-Anton Szandor LaVey
PostPosted: Tue May 31, 2005 12:29 pm    Post subject: Reply with quote
Yes, and No...
The lower a-arm is basically the same, there isn't any reinforcement on the arms anyway. But the method of sway bar attachment differs between the 80 931 and the 82-85/1 944 (with steel front a-arms).
The 944 a-arm does not have the "loop" for attaching the sway bar end that the 924 utilizes. The steel a-arm 944 uses a hole drilled in the middle of the "webbed" flat portion of the a-arm.
The VW Golf and Jetta a-arms are the same as the 924, and 944 steel a-arms, except they also do not have the "loop" to connect the 924 sway bar ends. You can buy new VW arms very cheaply, then have them reinforced by continuously welding the seam between the top and bottom, and adding a strip over the top and bottm flanges and welding to both sides. This is what was done on the factory competition cars.
On your 931, you can use the balljoint that is already on a 944 a-arm, as it will be the same part. You cannot use a 944 tie rod, or tie rod end, since all 944 cars used different steering racks (both manual and power versions).
jl924t
PostPosted: Tue May 31, 2005 12:42 pm    Post subject: Reply with quote
Do you need control arms?
1980 924 turbo
MunkPuppy
PostPosted: Sat Jun 04, 2005 10:01 am    Post subject: Reply with quote
I have sourced the a-arms at a wrecker for $50 each, but I do need the tie rod. If need be I will buy a new ball joint, I just don't know what size balljoint I need. Otherwise, I''ll have to try to straigten the existing tie rod, and I don't like that idea at all.
'80 931 FOR SALE
MunkPuppy
PostPosted: Wed Jun 08, 2005 12:07 pm    Post subject: Reply with quote
Update:
The lower control arms I got fit perfectly except for one small problem:
THERE'S NO MOUNT FOR THE ANTI-SWAY BAR! DOH!!!!!
Options: fabricate a mount and install with the 2 screw holes on the arm or MIG weld it on
OR
Take em back and ask for the right ones (which may cost more)
I may just ask for a refund and take u up on a conrtol arm, jl924t.
'80 931 FOR SALE
PostPosted: Wed Jun 08, 2005 1:24 pm    Post subject: Reply with quote
Yep, that's the "loop" that Gohim mentioned. I vote for welding pieces on. The a-arms with OE "loops" are stupidly expensive - something like 3x, 4x or more-x more than the "non-looped" ones.
jl924t
PostPosted: Wed Jun 08, 2005 1:42 pm    Post subject: Reply with quote
I have a pair here that I purchased last year from Michael in Bellingham. I just wanted to have a spare set just in case. You are welcome to take a look at them if you like. I could bring them out to you. Take a look at them and we can discuss price but first make sure you can get your money back from the wrecker.
1980 924 turbo
MunkPuppy
PostPosted: Thu Jun 09, 2005 12:02 pm    Post subject: Reply with quote
Appreciate the offer, jl924t, but I called the wrecker today and the guy just gave me the wrong set. They have another set already pulled and ready for pickup on Saturday.
If they DON'T have them like they say, then I will most definitely make some arrangements with you.
'80 931 FOR SALE
jl924t
PostPosted: Thu Jun 09, 2005 2:58 pm    Post subject: Reply with quote
No problem at all. I like having and extra set but i figure if you need them it's better to have them working on a car rather than sitting around. Good luck. PM me if you need them. Which wrecker did you locate your parts from? I may go check it out and see if there is anything I gotta have.
1980 924 turbo
MunkPuppy
PostPosted: Thu Jun 09, 2005 4:11 pm    Post subject: Reply with quote
Evolved Auto in Coquitlam,
you had best callem up and ask if they have a particular part, as most of their stuff is pre-pulled
'80 931 FOR SALE
5150
PostPosted: Thu Jun 09, 2005 5:18 pm    Post subject: Reply with quote
Smoothie, over here they arms with the loops on are something like 15x more expensive! I got the cheaper ones at the end of last year and modified them, think they were something like £16 gbp +tax while the others were around £240+!!!
Mars Red '78 Euro 924 n/a
There are two kinds of pedestrians: the quick and the dead.
