BillA
Joined: 27 Dec 2002 Posts: 170 Location: Syracuse, NY
Posted: Mon Jun 13, 2005 1:36 am Post subject: Won't Idle? |
My 78 924 won't idle, it'll start, just won't stay running. When I press on the pedal it dies intstantly? Checked the cold start valve, warm up regulator, and the rest, they proper working order. Timing is correct to what the Haynes manual calls for? The only thing I do notice is that as soon as I switch the key on the fuel pump starts ruuning? From past posts and reading the book, I thought the pump won't come on until you actually crank t he engine? Don't know much about the accumulators, would they be a factor? |
Joined: 29 Jul 2001 Posts: 9111 Location: Royal Oak, MI, USA
Posted: Mon Jun 13, 2005 2:13 am Post subject: |
I'm guessing the mixture setting is off. _________________ Vaughan Scott
teo
Joined: 07 Sep 2001 Posts: 637 Location: Hungary, Europe
Posted: Mon Jun 13, 2005 2:37 am Post subject: Re: Won't Idle? |
| BillA wrote: | The only thing I do notice is that as soon as I switch the key on the fuel pump starts ruuning? From past posts and reading the book, I thought the pump won't come on until you actually crank t he engine? |
Is it running for a few seconds, or is it running continously?
For a few sec's it's ok, if it stays on you have a bypassed fuel pump relay. The fuel pump relay is the top-left relay on the board. |
BillA
Posted: Mon Jun 13, 2005 3:30 am Post subject: Won't Idle |
Swapped out mixture unit runs like champ!
Thanks!!!  |
