passenger door sag?
Modoc
PostPosted: Fri Jun 03, 2005 2:15 pm    Post subject: passenger door sag? Reply with quote
My passenger door sags a bit when it closes... The pin stripe on the side doesnt nessiarly match up, and the weather striping is kind of rubbing at the top... Any idea on how to fix this problem? is it common on 924's?
thanks for your time guys
Proud owner of
'88 924s - Sold
'01 ML430
'97 Honda Civic
PostPosted: Fri Jun 03, 2005 3:25 pm    Post subject: Reply with quote
Probably just loose door hinge bolts.
PostPosted: Mon Jun 06, 2005 5:26 am    Post subject: Reply with quote
or worse check to see if one of the hinge brackets
hasnt cracked.
at the weld
