alxch1n15
Joined: 26 Nov 2004 Posts: 261 Location: Madison, Wisconsin
Posted: Wed Apr 13, 2005 1:56 am Post subject: heavy petal |
hey everyone,
so, when driving, does your petal seem hard to press? i guess a better explanation is that the petal isnt very repsonsive. and also, has anyone ever done tire repair? i seem to have a slow leak and want to fix it myself rather than taking it to the shop.
alex _________________ '81 924 n/a |
Chrenan
Posted: Wed Apr 13, 2005 2:04 am Post subject: |
Which pedal? Brake? Clutch? Accelerator? _________________ 1987 951 - M193 Version for Japan |
MAD-924
Posted: Wed Apr 13, 2005 2:45 am Post subject: |
First you need to find the leak. Is it at the bead or from the tread. Do this by putting water/soapy water all over the tire and look for bubbles. Or just look for the nail that's probably in the tread. You can buy a tire plug kit to fix a puncture in the tread (of course you need to remove the object from the tire before you can plug it BUT be sure you have the kit already in hand or your tire could go flat quickly once the object is pulled). If its the bead, it'll most likely need to go to the shop to have them maybe turn the tire on the rim unless of course you hit something with the wheel and bent the rim. IMO though, for the price, your better off taking it to a shop and letting them fix it with a tire "patch". Or you could shoot some Fix-a-flat into it. Goodluck. _________________ 79 924 Sebring |
alxch1n15
Posted: Wed Apr 13, 2005 3:05 am Post subject: |
whoops, sorry to leave out that information...it was a long night last night...ahem ...but its the accelerator pedal. _________________ '81 924 n/a |
Neil924
Posted: Wed Apr 13, 2005 3:11 am Post subject: Re: heavy petal |
| alxch1n15 wrote: | hey everyone,
alex |
I find the pedal feel in the 924 is different from other cars. Don't confuse different with difficult. Also, if your puncture is in the side wall, you must replace the tire and unless your set is brand new you may need to replace the tire opposite as well. Repairing by way of patch or plug a damaged sidewall is unsafe for you and other drivers since that part of the tire flexes quite a bit rendering your "fix" useless. |
Neil924
Posted: Wed Apr 13, 2005 3:12 am Post subject: |
| alxch1n15 wrote: | whoops, sorry to leave out that information...it was a long night last night...ahem ...but its the accelerator pedal. |
And where is your puncture? |
Posted: Wed Apr 13, 2005 5:15 am Post subject: |
The accellerator should be easy to press and it should return even easier when released. Possible causes if it's not moving freely are the throttle's gunked-up (pop the hood and turn it by hand to check that), throttle cable's rusted or gunked-up, the wrong spring - one that's too strong is installed at the throttle (if it's hard to push, but returns easy), or there's a tennis ball or some other junk stuck under the pedal.  _________________ "..it's made in Germany. You know the Germans always make good stuff."
alxch1n15
Posted: Wed Apr 13, 2005 8:03 am Post subject: |
so thats where my tennis ball went. umm...not quite sure where the puncture is, im at school, and am about two hours away from my car, so that wont be found until i can get home. the petal depresses easily, and springs back easily, but the reaction is terrible. so i think that the cables might have some junk on them. i know my responses might be a bit confusing...thanks for putting up with them _________________ '81 924 n/a |
Posted: Wed Apr 13, 2005 8:20 am Post subject: |
Could be a number of things.. I'd start by checking the vacuum, then ignition timing, valve timing, air filter, do a compression test. _________________ "..it's made in Germany. You know the Germans always make good stuff."
Roger
Posted: Wed Apr 13, 2005 1:35 pm Post subject: |
Repairing a flat is fairly easy. You can buy the kit at any auto parts store, and just plug the leak. We once got stranded on a camping trip with a flat. We used a section of the windsheild wiper hose and some rubber cement to plug the leak, but that is extreme. For the price I would recomend taking the tire off and having it patched _________________ 1981 924 NA
Posted: Wed Apr 13, 2005 1:42 pm Post subject: |
| Roger wrote: | | We used a section of the windsheild wiper hose and some rubber cement to plug the leak, |
What, were you camping with MacGyver?
...or maybe -you're- MacGyver?...hmmm  _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Wed Apr 13, 2005 3:11 pm Post subject: |
If the tyre has a tube and it gets a leak, a shoe lace tied around the puncture can work too. Remove tube, gather tube at the leak and tie up..
| Quote: | | We used a section of the windsheild wiper hose and some rubber cement to plug the leak, but that is extreme |
However for tubeless the small rubber hose pushed in with a screwdiver and heaps of rubber cement is the way to go. Old trick but one to be reminded of.
Mind you it is only for emergency repairs. _________________ Porsche 924 1984 (UK import) NA
Roger
Posted: Thu Apr 14, 2005 12:11 pm Post subject: |
| Smoothie wrote: | | Roger wrote: | | We used a section of the windsheild wiper hose and some rubber cement to plug the leak, |
...or maybe -you're- MacGyver?...hmmm  |
I had a buddy who grew up way out in the boonies of Alabama. He tought me all kinds of MacGyverish stuff. When the nearest gas station is a two day walk I guess you learn to be creative.
Today we call it thinking outside the box.
When my exhaust came loose one time it was draging and probably leaving a trail of sparks behind, I took three plastic shopping bags tore them into strips and braided an length of rope to tie up the exhaust and drive home. Glad I knew that guy from Alabama. _________________ 1981 924 NA
924guy
Posted: Thu Apr 14, 2005 12:47 pm Post subject: |
dont any of you guys carry a can of fix a flat ??  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
leadfoot
Posted: Thu Apr 14, 2005 1:05 pm Post subject: |
You guy would love a program they aired down here called The Bush Mechanics"
Some of the scenarios...
They used spinifex to stuff into the wheel to keep it inflated.
A clutch plate they made from wood off a stringybark if I remember correctly.
When they broke the wheel studs on the other side they made up a wooden skid and tied it to the trailing arm.
When they had problems with the brakes they used Omo (clothes washing powder) and water as brake fluid in a gravity feed container with a guy sitting on the bonnet holding it up.
When the fuel pump died they ripped out the windscreen washer tank and used the motor from that operating via the lever off the steering column.
I wish it was still on.
Leadfoot |
