prokuratuur
Joined: 06 Feb 2005 Posts: 3 Location: Tallinn,Estonia
Posted: Sun Feb 06, 2005 5:47 am Post subject: porsche 924 gt |
| Does someone have close pictures or blueprint of the 924 gt rear fender flares, if possible could you send me those to sayflurm@hot.ee ,thank you in advance. |
rice_beater
Joined: 29 Mar 2005 Posts: 41 Location: Sydney, Australia
Posted: Tue Mar 29, 2005 9:14 pm Post subject: |
| yeah, im new..I have also been looking for the rear fender flare bluprints, and i couldnt find 'em anywhere so if someone could tell me where to find 'em it would be greatly appricated |
turbobob9242
Joined: 08 Feb 2003 Posts: 138 Location: Hinckely Ohio
Vince Ponz
Posted: Fri Jun 03, 2005 12:04 am Post subject: |
I measured the distance from the bottom of the rear of the door to the placement of the flares and it is 1 7/8 in. Mark both of them in the same spot. Alignment is the key. I posted to another of your postings on what I did. Special bonding material.
This job is not for the faint hearted. Especially when you have to cut the body.
Drill holes in the new flares just for alignment. Then if you are happy with the look drill new holes without taking out the pilot holes. When you are happy with the fit screwed on the fender remove and epoxy it to the body with the screws holding it tight to the body. I will have to get you the name of the product. Fiberglass the holes and paint.
Important. I drilled holes only on the outside of the flares and then used self taping screws through the strip. If you go all the way through you will lose strength and the flares will move. I hope you understand this and if not you can call me. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
