mixture
sleepy
PostPosted: Mon May 16, 2005 9:08 am    Post subject: mixture Reply with quote
Got my new plug leads this week. After a bit of playing with the
accelerator while turning her over I eventually got her started.
Idling at not enough revs it sounds like its ready to cut out, but
sounding great at the higher revs. I didn't used to have to touch the
pedal to start it even tho idling was rough, but at the MOT (compulsary vehicle test in UK) a while ago the mixture was adjusted to get the Co2 reading closer to what its supposed to be.
Is it possible that because one of the old leads wasn't working, with the new leads the mixture will now be wrong ? I took the air
filter out & if i touch the (i think it's called?) air meter gently,
it idles normally.
Once it's been started it'll start again straight away.
-thanks.
meteor silver 1981 924 lux. -UK
PostPosted: Tue May 17, 2005 5:06 pm    Post subject: Reply with quote
If your MoT man leaned off the mixture, it's probable that the idle speed will have dropped.
All you need to do to get it back is to tweak the throttle bypass screw on the side of the throttle housing (the one in the little tube that sticks out of the housing).
Changing plug leads shouldn't have any effect on the mixture.
sleepy
PostPosted: Tue May 17, 2005 5:22 pm    Post subject: Reply with quote
my thinking was that if the mix was adjusted to compensate for a lack of spark, does it need to be adjusted now the spark is good?
PostPosted: Tue May 17, 2005 6:45 pm    Post subject: Reply with quote
Good point.
Lack of spark (or, more likely, intermittent spark) will certainly up the unburned hydrocarbon (HC) emissions. I can't quite see clearly what effect it would have on the CO level, but I suspect it might go [i]down[/i] with an iffy spark.
If the mixture was tweaked to lower the HC level with dodgy leads, you could be running dangerously lean, but I think it's unlikely. If your car pulls away strongly with a warm engine, the mixture's not too far on the lean side.
