ic932
Posted: Thu Mar 03, 2005 8:20 am Post subject: wheel spacers |
| I want to use 7 inch wide rims on the front of my 931.These rims have an offset of 65. Has anybody tried this setup? |
Posted: Thu Mar 03, 2005 12:50 pm Post subject: |
these wouldnt happen to be 928 S2 rims would they?
I am running 7" 928S rims on the back on my 924 and they have no clearance issues on front or back and iirc the offset is 65 on those rims _________________ 3 928s, |
ic932
Posted: Fri Mar 04, 2005 8:02 am Post subject: |
| not quite but they are 928 rims.They're club sport rim's.I think they are off a gt. |
924 turbo
Posted: Fri Mar 04, 2005 5:23 pm Post subject: |
I used a set of phonedials from a 928, 7" wide with 65mm offset. Without spacers they stick in 1" compared to the 52.3mm offset 6" rims. I used a 7mm spacer in the front and a 28mm 930 spacer in the back in place of the stock 21mm spacer, but I don't think it was really necessary to space them out. _________________ Jon Furst |
ic932
Posted: Sat Mar 05, 2005 7:51 am Post subject: |
| Thanks guys. For some reason I thought I'd be hitting the struts without spacers. |
ic932
Posted: Sat Mar 05, 2005 7:53 am Post subject: |
SoyRacer
Joined: 25 May 2003 Posts: 156 Location: Long Island, New York
Posted: Mon Mar 21, 2005 10:37 pm Post subject: |
I Am In The Process Of Fitting 16x8 (245-45-16) In The Rear Of My 931 And 16x7 (215-50-16) On The Front.
The Rear Was No Problem With A 15mm Spacer And I See No Real Problem With The Rim Hitting The Strut On The Front Without A Spacer.
The Original Front Tire Was Very Close To The Spring Though. Just Make Sure You Give Yourself Some Clearance.
Good Luck !! _________________ 1973 911-RS 3.2 Track Car
1981 Porsche 931/Carrera GT Project
1981 Porsche 931 Euro W/CGT Intercooler
1984 Porsche 944 Gutted Track Car
1987 Porsche 924s Rally Style (sold 3-2012)
2000 Chevy C-2500 Pick-up
2004 Subaru Forester STi |
ic932
Posted: Wed Mar 23, 2005 6:02 am Post subject: |
I've got 16x9 et60 with 245/45/16 on the back using 924S trailing arms.They fit perfectly and look the biz.On the front I've got 16x7 et65 with 205/50/16 tyres. Although they don't rub on the springs they could do with spacers to fill the fenders.
I'll probably reduce the rear tyre width or look for some 8's if the handling feels wrong.Any thoughts....? |
simsport
Joined: 06 Nov 2002 Posts: 573 Location: UK Warrington
Posted: Wed Mar 23, 2005 11:25 am Post subject: Rims |
I have 15 x 8 fronts and 15 x 9 rears....no problems with a 6 mm shim at the front and a 28mm spacer at rear. The rims are BBS replica. My body has been modified but looking at the clearance I think they would have fitted the standard body without the spacers.
Cheers
Simon _________________ Blown is always best! |
SoyRacer
Posted: Tue Mar 29, 2005 10:03 pm Post subject: |
ic932- I Fitted The Rims Today And The Only Issue Is An Asthetic One. The Front 7" Rim Seems To "Stick Out" A Little Too Far.
I Wish I Had Some Way Of Posting Pictures So That You Could Understand My Visual (No Pic Host).
It's Hard To Explain.
I'm Going To Re-Align The Car With Some More Negative Camber But I Can Only Go So Far Before The Inner Tire Sidewall Comes Too Close To The Spring.
Good Luck With Yours! |
Warwick
Posted: Tue Mar 29, 2005 11:40 pm Post subject: |
You guys with 15x9 and 16x9 rear rims. Any pictures? _________________ -78 924 NA
7x17 rims et 35 with 9 mm spacer front 34 mm rear.
Working on 5-bolt swap and supercharger kit. |
924guy
Posted: Wed Mar 30, 2005 12:23 am Post subject: |
| SoyRacer wrote: | ic932- I Fitted The Rims Today And The Only Issue Is An Asthetic One. The Front 7" Rim Seems To "Stick Out" A Little Too Far.
if you want, i can host the pics for you..just email them to me at my2porsche AT yahoo.com..
while were on the subject, ive got a set of 6" wide trash can lids with 225/50 16's on em, the tires will fit in the rear, though the inner lip will probably need to be rolled a bit , as it looks like theyll rub just slightly(cars still up on jacks so i havent put any weight on em.) wont be an issue with the gt flares though. they do look good from the rear though.  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
ic932
Posted: Wed Apr 06, 2005 8:21 pm Post subject: |
924guy would you mind hosting some pics for me.I'm new to the digital world but I think I just about know how to email pics.  |
924guy
Posted: Wed Apr 06, 2005 10:52 pm Post subject: |
no problem.. send them to me at : my2porsche AT yahoo.com, and ill stick em up..... _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Kenodog
Posted: Sun Apr 10, 2005 6:32 am Post subject: |
I put 7" S2 rims on the front using the stock spacers and 8" on the backs.I had to get a machinist buddy to take 1/4" off of the rear spacers to get the tire so it won't rub the body if the suspension bottoms out though. _________________ 1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
