kevinduffy
Joined: 06 May 2005 Posts: 2 Location: Palm Coast, FL
Posted: Fri May 06, 2005 10:35 am Post subject: 924S Oil Pressure Gauge Readings... |
I have an '88 924S US car. As with other 924/944 cars I have owned, the oil pressure gauge always reads 5 bar + when the engine is running. Recently, the gauge housing cracked and a bought a new VDO OP Gauge that reads in PSI. When I installed it, it also reads MAX psi!!!\\
Where do I look next? OP sending unit?
Thanks _________________ 88 924S - soon to be a replica 924GT |
Posted: Fri May 06, 2005 12:37 pm Post subject: |
Unhook the wire from the OP sender and see what the gauge reads (with the motor running).
If it's still 5, you most likey have a short in the wiring from the sender to the gauge.
If it reads 0, you have a bad OP sender. _________________ White 87 924S "Ghost"
edh
Posted: Fri May 06, 2005 5:43 pm Post subject: |
Does the pressure read at max. when ignition is on but engine not running? - mine did this & I just replaced the pressure sender. _________________ current - '90 944S2, '00 986S,
ex - '90 944 turbo '86 924S, '88 924S |
