A/C malfunction
Llamaguy
PostPosted: Mon May 02, 2005 6:13 am    Post subject: A/C malfunction Reply with quote
last night the ac stopped blowing out the right places, it made a really load air noise and only came out under the a/c box on the passenger side. The heater still worked, just not the center a/c knob. This morning it worked fine again, what in the world is happening?
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
PostPosted: Mon May 02, 2005 6:50 am    Post subject: Reply with quote
The AC's supposed to pull air -in- through that area at the passengers' footwell. I wonder if something happened to the motor and/or wiring to make it start spinning in the opposite direction. -Or maybe the clips holding the assembly popped off? -Or a duct pipe came loose? Maybe a vacuum line fell off a flap actuator? You can remove the glove box to get access and look at the top side of the AC blower and other AC parts.
924guy
PostPosted: Mon May 02, 2005 10:23 am    Post subject: Reply with quote
sounds like the flaps got stuck, maybe a wire or controll cable got hung up and now its freed itself?? stranger things have happened...
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
PostPosted: Mon May 02, 2005 10:25 am    Post subject: Reply with quote
A/C? It's SNOWING HERE!
Llamaguy
PostPosted: Mon May 02, 2005 2:11 pm    Post subject: Reply with quote
Don't worry, it doesn't really work anyways, It just isn't scolding hot. It snowed last week, but it's supposed to be in the 70's this time of year.
