maireeka
Joined: 29 Aug 2004 Posts: 299 Location: North Alabama
Posted: Wed Apr 20, 2005 8:56 am Post subject: coolant/backfiring |
totally unrelated questions.
1. If my coolant res. needs topped off, do I have to use coolant or can I just put a little water in there? It's not dangerous, the car cools off very well, it just needs a little more.
2. I get a little backfiring when I get off the throttle when revving/driving/anytime. It's real subtle, but needs to be fixed. Is ignition timing the most likely culprit? _________________ 1977 Porsche 924 red and READY! |
numbbers
Posted: Wed Apr 20, 2005 9:17 am Post subject: |
As long as it is not below frezzing, water is a better coolant than antifreeze. In your climate, it probably doesn't get below freezing very often, so, toping off with water should not cause a problem. The water will quickly mix with the coolant, and not dilute it much. _________________ 1980 924 Turbo |
maireeka
Posted: Wed Apr 20, 2005 9:33 am Post subject: |
cool, so it's okay even to use straight water during the summer? _________________ 1977 Porsche 924 red and READY! |
tj924
Joined: 15 Jul 2004 Posts: 957 Location: Toowoomba, Queensland, Australia
Posted: Wed Apr 20, 2005 10:41 am Post subject: |
| maireeka wrote: | | cool, so it's okay even to use straight water during the summer? |
Yes, but according to others on the board, use distilled water rather than tap water (minerals from the water will get deposited in the engine) or demineralised (will pull minerals out of the metal in the engine).
Also bleed the system again any time you remove the cap (remove the cap & bleeder plug, top off with water or whatever, replace the cap, start the engine & run at around 1500 rpm until coolant is running steadily from the bleeder hole, replace the bleeder plug).
I've also seen a few people talk about "water wetter", but I've never used it. _________________ TJ
Silver '82 924 NA 5-Speed Manual |
Posted: Wed Apr 20, 2005 11:26 am Post subject: |
I wouldn't go with straight 100% water except in an emergency. Antifreeze also serves as a coolant and raises the boiling point above waters' usual 100°C/212°F. Approx. 30%-50% of what's in the cooling system should be antifreeze/coolant, depending on your climate. Adding water only to an antifreeze-water mix is generally ok to do, but it dilutes the mix, so obviously if it's done too much you'll lose some of the boilover protection. _________________ "..it's made in Germany. You know the Germans always make good stuff."
tj924
Posted: Wed Apr 20, 2005 11:36 am Post subject: |
| Smoothie wrote: | | Approx. 30%-50% of what's in the cooling system should be antifreeze/coolant, depending on your climate |
The coolant I use recommends 25% coolant to 75% water. _________________ TJ
Roger
Posted: Wed Apr 20, 2005 1:07 pm Post subject: |
If it just needs to be toped of then water is fine. However you do not want to dilute the mix too much, but a little water wont hurt.
Backfire is usually caused by a lean fuel mixture _________________ 1981 924 NA
924zombie
Posted: Wed Apr 20, 2005 6:13 pm Post subject: |
| Anti-freeze is also a corrosion inhibitor,if you have your car with just water in the cooling system it starts to corrode the aluminium head. |
