Auxillary air valve stuck closed
pyromjm
PostPosted: Wed Apr 27, 2005 12:01 pm    Post subject: Auxillary air valve stuck closed Reply with quote
I think my aux air valve is stuck closed, i just stuck it in the freezer and will check it in about 10 minutes to see if that made it open up at all. The resistance on the heating part is at 43 ohms, the haynes says it shoudl be at 30. Should it be getting 12 volts all the time when the ignition is turned on? i checked to see if the plug that goes to it had any voltage but i didnt read anything with the key in the on position.
Does anyone know a good place to get a replacement aux air valve is mine is really dead? Thanks a lot,
-Mike
1982 924 NA gray/silver with black int.
Roger
PostPosted: Wed Apr 27, 2005 12:30 pm    Post subject: Reply with quote
Cant remember where I got mine probably Auto Atlanta or Performance Products
1981 924 NA
pyromjm
PostPosted: Wed Apr 27, 2005 12:33 pm    Post subject: Reply with quote
Does 100 bucks sound right? seems kind of expensive...
http://www2.9parts.com/parts/parts1/9parts/wizard.jsp?year=1982&make=PO&model=924--001&category=B&&part=Auxiliary+Air+Valve
Gram
PostPosted: Wed Apr 27, 2005 12:37 pm    Post subject: Reply with quote
Did it open in the freezer? I think I measured mine at 48 ohms.
'82 924 NA Euro (hers)
'98 Audi A4 TDI (ours)
Gram
PostPosted: Wed Apr 27, 2005 12:38 pm    Post subject: Reply with quote
And IIRC it only has 12V on it when the motor is running..power is cut by the fuel pump relay.
Roger
PostPosted: Wed Apr 27, 2005 12:40 pm    Post subject: Reply with quote
OK I pulled the records mine was from Performance Products $53.56 part number 903890.
1981 924 NA
pyromjm
PostPosted: Wed Apr 27, 2005 12:43 pm    Post subject: Reply with quote
Thanks for the info Gram, and Roger, i checked some sites performanceproducts says they dont have them now.. but paragon products says the ones from '77-'80 are 57.80, but the ones from 81-82 are $93 dollars... that sucks...
Roger
PostPosted: Wed Apr 27, 2005 12:52 pm    Post subject: Reply with quote
You might try the local junkyard. Many CIS (Audi, VW, Saab, Volvo) systems used the same part.
1981 924 NA
