formula05
Posted: Tue Apr 05, 2005 2:39 pm Post subject: My 924 is ALiVE aGain! |
I Finally got the DME computer back. I had Re-Solder work done Now the car runs like a champ. The car starts up with no hesitation and run good. Now i'm going to check the timing belt and see if it need front end service. I'd like to also get the A.C working. I'm going to see what it needs. If anyone has any advice on checking the A.C units i'd appreciate it.
thanks _________________ 1987 Porsche 924 |
Posted: Tue Apr 05, 2005 3:11 pm Post subject: |
as for the timing belt, just an fyi the belt can look fine and then strip teeth the next day, DONT go by looks _________________ 3 928s, |
The Fife
Joined: 17 Mar 2004 Posts: 241 Location: San Antonio, Texas
Posted: Wed Apr 06, 2005 10:59 am Post subject: |
| Yeah, new timing belts are cheap and easy to fix compared with replacing bent valves. I've had V belts blow before with no warning too. |
