Rims, WIll they fit?
collin41899
PostPosted: Tue Apr 05, 2005 7:44 am    Post subject: Rims, WIll they fit? Reply with quote
CAN anyone tell me if these rims will fit a 77 924. They are enkei
4x4 1/4. Heres the link:
http://www.discounttiredirect.com/direct/findWheelDetail.do?wd=17&c=3&pc=51097&rw=7&bp=4-108
Collin
yellow 1977 924 turbo!?!
john h
PostPosted: Tue Apr 05, 2005 8:56 am    Post subject: Reply with quote
The bolt pattern is correct at 4 x 108 - what you will have to check is that the wheel is not set up too much like a front wheel drive car - in which case the inner wall of the tire will hit the strut at the front and maybe inner fender at the back.
cause it's 17 inch you'll have no trouble clearing the brakes
the normal 924 has an offset of 20mm on a 6 inch rim so the 40mm offset on the 7 inch rim would bring the rim closer to the front strut by 32.5 mm
Usual story - try before buying - if the tire shop won't let you do that then the chances are they already know they won't really fit.
PostPosted: Tue Apr 05, 2005 10:46 pm    Post subject: Reply with quote
So what does this mean? I'm assuming you'd need to add spacers ... how big would be sufficient? Also, my car takes lug bolts (72mm version) as opposed to having studs and lug nuts. How do I know if the cup on the head of the bolt is shaped properly for an aftermarket wheel?
I'd consider adding 16x7 4-108's to my 4-bolt setup if I could figure out the right offset and spacer setup. Right now I'm running the 15" 4-bolt spiderwebs.
collin41899
PostPosted: Thu Apr 07, 2005 11:40 am    Post subject: Reply with quote
yea, what size spacers would i need to make these rims work?
Or is it more than spacers? Any suggestions?
Collin
