OT: Are You Mechanoid?
PostPosted: Tue Apr 15, 2008 3:44 am    Post subject: OT: Are You Mechanoid? Reply with quote
I was having a conversation with a buddy at the track last week, and he said something that got me thinking. He had just experienced a compression leak in his 951 into the water jacket, so he pulled the head, and found the head gasket intact. This left him doubting his mechanical prowess, and as a result he took it easy on the car at the track (the car is a Lindsey Stage III monster. . .500+ whp).
The condition my friend suffers from is mechanioa, an irrational fear of mechanical failure.
Related conditions and their symptoms follow:
smellanoia - you can smell coolant leaking from any car within a 2 block radius, and wonder if it is coming from your car; same applies to hot or burnt oil smells, and fuel smells; you immediately stop, and passing motorists gape as you bend over your engine compartment, sniffing vigorously
hearanoia - a jackhammer over at the mall sounds exactly like a rod knock; you pull over and check your oil
gauganoia - you worry about variations in temp and oil pressure readings that are not detectable to the naked eye; this sometimes keeps you from sleeping.
turbonoia - your face looks like this:
Any other symptoms you can think of? Potential cures?
Discuss!
Rich H
PostPosted: Tue Apr 15, 2008 3:57 am    Post subject: Reply with quote
Paranoia - You have just bought a car (Normally a Lotus) you know nothing about that has a reputation for blowing up in spectacular fashion with no warranty cover...
Are you paranoid enough?
PostPosted: Tue Apr 15, 2008 4:00 am    Post subject: Reply with quote
Rich, anyone who does that is more likely suffering from noghivashytis.
Rich H
PostPosted: Tue Apr 15, 2008 4:03 am    Post subject: Reply with quote
You have clearly never owned a Lotus or TVR
PostPosted: Tue Apr 15, 2008 4:14 am    Post subject: Reply with quote
Markanoia
The fear that every new member to the board is out to rip you off.
Nemaphobia
A genuine fear of becoming the next victim.
No I'm not obsessed. Those are (perhaps lame) attempts at self-effacing humo(u)r.
Exhaustion
A Timstar-like obsession with headaches caused by every vague whiff of NOX and CO.
Spares-aphobia
An illogical fear that one will never again ever be able to find used or replacement parts.
PackRat-aphyxia
A symptom often accompanying Spares-aphobia characterized by endless hours of rooting through internet ads on eBay, Craigslist, and other discussion forums. Sufferers of this malady often pay twice the going rate for used parts, and can be identified by garages, basements and attics overflowing with piles of parts they'll probably never actually use on any of their cars.
PostPosted: Tue Apr 15, 2008 4:18 am    Post subject: Reply with quote
I totally have the last two there, Dan. And the first two? They crossed my mind, but I left the door open for ya. . .
PostPosted: Tue Apr 15, 2008 4:25 am    Post subject: Reply with quote
PackRat-aphyxia
Ha, that's what I get for letting you see the inside of my storage unit...
PostPosted: Tue Apr 15, 2008 4:31 am    Post subject: Reply with quote
I was referring to my own garage...but now that you mention it...wow, that was an amazing amount of stuff you had crammed into that unit!!!
PostPosted: Tue Apr 15, 2008 4:39 am    Post subject: Reply with quote
Heh heh... that's what she said...
Neil924
PostPosted: Tue Apr 15, 2008 6:22 am    Post subject: Reply with quote
I can't fix my car by myself so I do suffer from well, all of the above.
PostPosted: Thu May 08, 2008 7:21 am    Post subject: Reply with quote
Snipersaurus Rex
OK, not exactly a phobia, but this is that prick who ruthlessly takes advantage of 6MBS internet connection, multiple tabs in Firefox, and snipes the best auctions with only 3 seconds to go
Auctionaholsim
Addicted to eBay. No further description required.
5150
PostPosted: Thu May 08, 2008 7:43 am    Post subject: Reply with quote
Timstarphobia He's gone, but not far enough, you know he's still lurking around like the boogey-man under your bed you know he'll suddenly spring out and scare the living shit out of you!
Mars Red '78 Euro 924 n/a
http://www.cardomain.com/id/5150_uk
Graphite? Grey Metallic '85 (late model) 944 2.5
There are two kinds of pedestrians: the quick and the dead.
mgatlag
PostPosted: Thu May 08, 2008 7:55 am    Post subject: Reply with quote
Auctionaholism....
Uh..guilty. You know it's bad when you just type in Porsche or 924 Porsche in the search not really knowing what you're wanting but are VERY sure you'll find something you think you may need from the 900+ items that pop up.
Don't forget 924boardanoia: fear/anger felt when you try to get on the internet and find that you're having connection problems and you're really wanting to check a response from a thread you posted.
Michael
'04 Ford Taurus - gone!!
(Slap Shot)
PostPosted: Thu May 08, 2008 8:01 am    Post subject: Reply with quote
mgatlag wrote:
Auctionaholism....
Uhhh....heheh...uhhh...what do you call it when you have several highly targeted advanced searches set up so you can filter out 931 stuff from NA stuff from 924S stuff from 951 stuff from...well, you get the idea...
Martijnus
PostPosted: Thu May 08, 2008 8:07 am    Post subject: Reply with quote
nice one.
I definetely got some of the mentioned psychodeviations.
It can be cured only by getting another object to catch all your attention and/or selling the current object.
Either way no option
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
