Diesel
Joined: 03 Nov 2002 Posts: 1061 Location: Ellington,CT
Posted: Wed Apr 06, 2005 8:07 pm Post subject: What's the timing on your underhood sticker? |
Particularly, I need to know what a 78's timing is supposed to be. I'd like someone with an intact underhood sticker to tell me what it says. Thanks fellas. _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
AznDrgn
Joined: 03 Nov 2002 Posts: 1188 Location: Harrisonburg/Alexandria, Va
Posted: Wed Apr 06, 2005 11:52 pm Post subject: |
3 degrees _________________ -'87 Jeep Cherokee 4.0L 6" of lift 33" Super Swampers
-'83 Callaway 944 2.5L turbo, 300HP, 1 of 42 ever made |
Diesel
Posted: Thu Apr 07, 2005 2:26 am Post subject: |
| Before or after TDC? |
AznDrgn
Posted: Thu Apr 07, 2005 4:48 am Post subject: |
Before TDC _________________ -'87 Jeep Cherokee 4.0L 6" of lift 33" Super Swampers
Posted: Thu Apr 07, 2005 4:54 am Post subject: |
Haynes says 3° ATDC, timing mark '-3' with hoses connected. Is that another Haynes mistake needing correction? pg 123 _________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Thu Apr 07, 2005 6:56 am Post subject: |
Its 3 deg ATDC which makes -3 correct.
If it was BTDC then ??? _________________ Porsche 924 1984 (UK import) NA
Diesel
Posted: Thu Apr 07, 2005 7:41 am Post subject: |
Thanks for the info fellas.  _________________ Dan Flanagan--2002 VW Jetta TDI, 83 Mercedes 300D,83 Mercedes Euro-240D |
augidog
Posted: Thu Apr 07, 2005 9:35 am Post subject: |
| Smoothie wrote: | | Haynes says 3° ATDC, timing mark '-3' with hoses connected. Is that another Haynes mistake needing correction? pg 123 |
No I don't think so. With the vacuum hose attached you get a vacuum retard deal happening. The vacuum retard is about 6-8 degrees.
I agree its not very clear and caused a lot of frustration for me for a long time until someone called it out a while back on my similar post. _________________ 1978 924 95 mile daily driver.
AznDrgn
Posted: Thu Apr 07, 2005 10:59 am Post subject: |
hmm maybe I should double check my car again, I was pretty sure it said 3 BTDC. _________________ -'87 Jeep Cherokee 4.0L 6" of lift 33" Super Swampers
