new starting problems!
CBass
PostPosted: Sat Nov 05, 2005 6:26 am    Post subject: new starting problems! Reply with quote
I pulled the dash from my 924 while doing the battery tray repair which is still underway, but I need to move the car and now it won't start.
The engine cranks over just fine, I know the battery is good because it's not 6 months old and has been working great. After being left in a leaky car for a few months, my multimeter seems to have taken a turn for the worse and is reading my battery voltage at 1600 volts. It tells me I'm getting 600 volts at the coil with the ignition switched on. Time for a new multimeter, but shouldn't this read the same voltage as the battery?
I'm going to jump the #15 circuit and starter at the switch and see if this helps. Failing this, is there a better way to do it from under the hood, at the ignition module or something?
CBass
PostPosted: Sun Nov 06, 2005 6:13 am    Post subject: Reply with quote
Hmm, this isn't very reassuring, no replies
I have an idea I am going to try however. The starter circuit is working very well, the engine is cranking over with authority and the battery has a great charge. So my notion is to pull some chicanery and power the ignition through a fused switch, directly to the ignition module itself.
I already have the fuel pump running off a fused switch as it is, so I should be able to encorporate it with an extra relay and a small switch in the centre console. I'd have to turn off the switch to shut off the engine, but I have to switch off the pump when I turn off the engine anyways.
Any thoughts, or reasons why I really shouldn't do this? It'd still take the key to start the car, so if someone wanted to steal it they'd have to hotwire it anyways.
Another idea I have going is a master power switch that will disconnect the entire electrical system in case of a fire, or vehicle storage. I would keep an always closed circuit for the clock, stereo, and to power a relay to connect and disconnect the main power of course. How realistic is it to get a 12v relay that will be beefy enough to handle the current drawn at engine start?
CBass
PostPosted: Sun Nov 06, 2005 6:24 am    Post subject: Reply with quote
additional thought, I hate wiring.
Tigger937
PostPosted: Sun Nov 06, 2005 7:05 am    Post subject: Reply with quote
I don't see any reason why this shouldn't work. If the contact in your ignition switch that provides battery power to circuit #15 is bad, this should remedy your problem. Haynes is showing a 1 ohm resistor between the ignition module and the coil #15 terminal, so I don't think you want to connect directly to the coil with the battery.
I know Ford used to use a starter relay in this manner, don't know if they still do or not. The relay was a pretty hefty one, slightly smaller than a baseball. Should be able to get one from a boneyard.
1981 931 (Concours)
1982 931 (Daily Driver)
"Think outside the box"
CBass
PostPosted: Sun Nov 06, 2005 7:27 am    Post subject: Reply with quote
I'd be bypassing the relay/fuseboard and the ignition switch, with a fused wire between the #30 circuit powering the board and the wire which powers the ignition module itself. Unless it's shorted somewhere and melted itself during the process of pulling the dash, while the battery was disconnected , that wire should still be good. I'll check it for continuity and resistance before starting to be sure though.
Does this sound like a good idea, or am I missing something important?
Thanks for reminding me, I already have one of those remote starter relays, and it'll work great!
Tigger937
PostPosted: Sun Nov 06, 2005 8:27 am    Post subject: Reply with quote
It doesn't appear from Haynes that the relay/fuseboard is providing any fusing or relay functionality to this circuit, only a junction point. You'd be bypassing the ignition switch contact and associated wiring for this circuit. Is this a good idea? Well, I wouldn't leave it this way permanent. You indicated this would be temporary, ie., for just moving the car and it should be OK for that. With it bypassed like this, shutting off the key will not shut off the engine. (It will, however, disable the cooling fan circuit amongst other things.) You need to be concerned about the consequences of your wiring modifications in an accident or emergency situation.
1981 931 (Concours)
CBass
PostPosted: Sun Nov 06, 2005 10:02 am    Post subject: Reply with quote
Scratch that, I got my multimeter working properly. It tells me my battery is at 16.8 volts
I'm getting that same 16.8 volts at the coil and the plug for the ignition module. The kicker is, when I plug the MP plug into the ignition module, I get nothing at the coil. Not even 6 volts anymore. So this shows my ignition switch and wiring to be good, but points to a bad transistor unit, doesn't it?
If that's the case, I have a spare and I can think of two likely cases that could have cause it. Exposure to water, since the hood was off and it got sprinkled on a bit, and that ludicrously high 16.8 volt battery charge. Can overcharging a battery kill an ignition module?
CBass
PostPosted: Sun Nov 06, 2005 10:22 am    Post subject: Reply with quote
Gotta say, a diesel is sounding pretty attractive right now.
PostPosted: Sun Nov 06, 2005 10:33 am    Post subject: Reply with quote
Thats rough .. goodluck fixin the no start.
CBass
PostPosted: Sun Nov 06, 2005 10:59 am    Post subject: Reply with quote
Disregard all of the given voltage measurements here, just checked my multimeter against a wire and plug into a house receptacle and got a fluctuating voltage between 3 and 8 volts. Now call me crazy, but that should be reading 110-115 volts. Good thing Mastercraft has a warranty on all their tools.
leadfoot
PostPosted: Sun Nov 06, 2005 3:35 pm    Post subject: Reply with quote
Are you measuring DC current on that appliance, I'd be getting a new multimeter as it seems like yours is malfunctioning or at least checking the battery in it first...
If you are truly getting 16.8V at the battery then this would mean your alternator regulator needs a look at.
Leadfoot
1981 ROW 924 Turbo -
carbon fiber GT mish mash
LS1 conversion in progress...
CBass
PostPosted: Mon Nov 07, 2005 3:55 am    Post subject: Reply with quote
Oops, turns out it was set to DC. Checked the 110v outlet again, got readings 160v and 1660v depending on the setting I used. Are teh two different settings for single phase and three phase?
I'll replace the battery, and failing that replace the unit...
Tigger937
PostPosted: Mon Nov 07, 2005 4:37 am    Post subject: Reply with quote
Couple things. First, make sure the unit is not set for PEAK measurement when in AC mode. Should be set for RMS. Some of the fancier multimeters have this capability. If it is set in PEAK, you will read approximately 160 V.
Second, are you sure that's not 166.0 V?
Third, you should be set for single phase.
Fourth, I've never heard of a battery putting out 16.8 V without the alternator running. And if the alternator is putting out that much voltage, then leadfoot is right, your voltage regulator may be shot. If your regulator has indeed been putting out that much voltage, your battery is being cooked. Check the water level as it is probably very low.
1981 931 (Concours)
CBass
PostPosted: Mon Nov 07, 2005 7:31 am    Post subject: Reply with quote
Replaced the battery in the multimeter and now it tells me I've got 12 volts. Replaced the ignition module with a spare and it still won't start. Checked at the coil and I'm getting voltages that are ok according to the haynes manual.
One thing I was checking for was the resistance of the coil, I got 1.2 ohms between the coils, but it tells me to check the resistance between the #1 terminal and the #4, which is the lead to the distributor correct? I get no reading on the coil, or on my spare coil which is in a working engine.
Still no start...
PostPosted: Mon Nov 07, 2005 7:59 am    Post subject: Reply with quote
Obvious, but I'd be looking for something that got disconnected with the dash removal.
