Helstrm
Joined: 05 Feb 2005 Posts: 198 Location: Columbia, SC
Posted: Thu Feb 24, 2005 10:45 am Post subject: Powder Coating |
I got a hold of an oven and a powder gun..... This thing rox!!
lordam
Joined: 31 Dec 2002 Posts: 46 Location: New South Wales
Posted: Thu Feb 24, 2005 7:24 pm Post subject: |
OK I'll bite. That looks good, so ........
what paint?
what temperature in the oven?
how long in the oven?
what type of spray gun (or modifications to the gun)?
John |
Helstrm
Posted: Thu Feb 24, 2005 11:05 pm Post subject: |
It's not paint. Powder coating is a process where a finely ground powder is sprayed at very low pressure from an electrically charged gun. The cleaned and bare metal part is grounded, the gun is charged to 10,000 volts to give the particles a very high electrical charge. The particles are instantly drawn to the part, adhering to the charged surface. The part is then baked (high-temperature cured) and, as soon as it is cooled, is ready to go.
After beadblasting the part you wash it down with soap and water then blow it dry. Apply the powder and bake it at 400 degrees for about 20 minutes. |
D Hook
Posted: Thu Feb 24, 2005 11:41 pm Post subject: |
Car and Driver once described the 944 manifold as looking like a "bunch of bananas". Looks like you've done it right!
Can you tell us your sources for the equipment and associated costs?
The manifold looks great! |
Helstrm
Posted: Fri Feb 25, 2005 12:03 am Post subject: |
http://www.columbiacoatings.com/
I bought the oven from a local hardware store.... Total cost for the oven and gun is around $300
Powder Gun - Includes Powder Coat System, Foot Switch, Power Source, Inline Filter, Two 12 oz Powder Cups and Basic Powder Coating Instructions. $70 and up depending on which gun you use. |
Johno
Joined: 14 Oct 2003 Posts: 53 Location: Greendale, WI
Posted: Fri Feb 25, 2005 4:33 am Post subject: |
Very nice, for those of us in the States, Harbor Freight also carries a powder gun and oven. Don't know the price off hand but should be around the 300 mark by the time you are done. _________________ 79 924 NA |
CMXXXI
Posted: Fri Feb 25, 2005 5:34 am Post subject: |
OK, I'm jealous. Maybe this will be my "big gift" next Christmas.
| Helstrm wrote: | | ...After beadblasting the part you wash it down with soap and water then blow it dry... |
I had some parts done by a guy who has built a couple of really nice street rods, and he told me that in his experience, unless he does a final wash in acetone, the finished product has a tendency to crack/peel or otherwise come off after a while. In his words, things must be "immaculately clean" before applying the powder and baking. _________________ '79 Eurospec 931 |
D Hook
Posted: Fri Feb 25, 2005 5:50 am Post subject: |
| Good info. What's the temp needed from the oven? |
My924gtc
Posted: Fri Feb 25, 2005 5:57 am Post subject: |
400 degrees.
You can also use infrared curing lamps or propane systems.
It is the object being coated that needs to reach 400 in order for the powder to flash. _________________ MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands" |
Helstrm
Posted: Fri Feb 25, 2005 6:16 am Post subject: |
| CMXXXI wrote: | OK, I'm jealous. Maybe this will be my "big gift" next Christmas.
I had some parts done by a guy who has built a couple of really nice street rods, and he told me that in his experience, unless he does a final wash in acetone, the finished product has a tendency to crack/peel or otherwise come off after a while. In his words, things must be "immaculately clean" before applying the powder and baking. |
he is right.. We did wash them down in acetone I just left that very important step out.  |
