god help me or send some mechanical advice?
924pimped
PostPosted: Sat Jan 29, 2005 2:30 pm    Post subject: god help me or send some mechanical advice? Reply with quote
i have a 924 1980. love the car and i do all my own work. recently this new issue has stumped me. 3 days ago it started to idle erratically then stopped all together that night . that night i found it super hard to start then once started had to hold the gas down a little to keep it alive. i took out the injectors to run a test and found that next to no gas comes out. i took all lines apart to make sure theres no clog and removed the fuel distributor to pull up and down on the control piston ,that was operational.....the only things i can think of are the control pressure regulator or the accumulator...but i dont know it gets fuel in but wont come out the injectors unless i hold the sensor plate up....
someone help me pleaseeeeeeeeeeeeeeeeeeeeeee
got a 1980 924
jpab924
Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
PostPosted: Sat Jan 29, 2005 3:00 pm    Post subject: Reply with quote
Sorry, but you are a little hard to understand.
You will not get any fuel flow by moving the sensor plate (the big round flap looking thing) unless the fuel pump relay is jumpered.
There are plenty of people on this board that can help you with your malady, but you have to be a little more concise.
tj924
PostPosted: Sat Jan 29, 2005 3:01 pm    Post subject: Reply with quote
According to this thread, you need to open the air sensor plate to get fuel to the injectors.
TJ
Silver '82 924 NA 5-Speed Manual
924martinirossi
PostPosted: Sat Jan 29, 2005 3:14 pm    Post subject: Reply with quote
Make sure that the air boot is securely attached to the metering unit. I had it loosen up and the car sucked air directly in to metering plate and I had to keep on the gas. Normaly it is not a problem untill you are on a race track!
MIchael
924pimped
PostPosted: Sun Jan 30, 2005 2:44 am    Post subject: to be more clear Reply with quote
i took out the injectors to run a test by bridging the 87 and 30 lines. I found that next to no gas comes out. i took all lines apart to make sure theres no clog and removed the fuel distributor to pull up and down on the control piston ,that was operational.....its getting fuel inside but the pressure in the lower chamber is so much that when i pull up on the sensor plate its very difficult because of overpressurization... the only things i can think of are the control pressure regulator or the accumulator
thanks all
got a 1980 924
924pimped
thanks all
got a 1980 924
gohim
PostPosted: Sun Jan 30, 2005 9:01 am    Post subject: Reply with quote
The control pressure is regulated by the warm up regulator when the engine temperature is cold.
You do not need to jumper the fuel pump relay to test the fuel pumps simply turning the ignition key to "run" and lifting the airflow sensor plate should cause fuel to spray from each injector in a fan pattern. Are you sure that both of your fuel pumps are good? Has the car ever sat for an extended period, or been run out of gas? If so, then there is a good chance that you have a fuel pump problem. If one fails, the remaining fuel pump will not be strong enough to supply full pressure under all conditions, without removing the dead pump from the line.
dpw928
PostPosted: Sun Jan 30, 2005 12:08 pm    Post subject: Reply with quote
How old is your fuel filter?
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Sun Jan 30, 2005 3:37 pm    Post subject: Reply with quote
sounds like a fuel dizzy issue...if the pumps worken do a test to see how much fuel comes out at the fuel filter then again do the test at the fuel return line..just like the HAYNES manual says to.
924pimped
PostPosted: Mon Jan 31, 2005 3:24 am    Post subject: found more info Reply with quote
it seems that when i take out the pressure regulating valve in the fuel distributor, the fuel flows freely with low current cunsumption. its almost as if there is something wrong in the fuel distributor how often do these go out???????????????????????????????????
got a 1980 924
dpw928
PostPosted: Mon Jan 31, 2005 4:50 am    Post subject: Reply with quote
My 80 NA ran for over 300K with the same fuel distributor. The key word is "ran". If allowed to sit and lacquer up the fuel distributor will plug and cause the internal o rings to deteriorate. The valve control the system pressure and directs excess fuel back to the tank. Is the o ring on the end of the valve in good shape? Have you measured system and control pressures?
Dennis
81 931 5 sp
78 928 5 sp Silver
PostPosted: Mon Jan 31, 2005 12:30 pm    Post subject: Reply with quote
Bet'cha a buck one or both of the fuel pumps have packed it in...
CMXXXI
PostPosted: Tue Feb 01, 2005 5:14 am    Post subject: Reply with quote
Are both pumps working? What is your measured delivery rate/volume? What is the measured system pressure? What is your measured control pressure? The answers to these questions will really, really help you track down the problem.
The fuel distributor has to get enough fuel at the correct pressure in order to do it's job.
'79 Eurospec 931
