fuel distributor
kewpie79
PostPosted: Mon May 02, 2005 3:21 am    Post subject: fuel distributor Reply with quote
Where is it and how do you check it? I've searched, but all they say is check the fuel distributor.
1980 Porsche 924
1984 Pontiac Grand Prix
2003 Kia Sorento
pyromjm
PostPosted: Mon May 02, 2005 4:36 am    Post subject: Reply with quote
Its attached to the air box, mine is black and has a bunch of steel fuel lines coming off of it. it should be just to the left of where u put the filter in. when i get home ill take a picture.
-Mike
1982 924 NA gray/silver with black int.
kewpie79
PostPosted: Mon May 02, 2005 4:57 am    Post subject: Reply with quote
found it, how do you check it to see if it is working?
1980 Porsche 924
2003 Kia Sorento
pyromjm
PostPosted: Mon May 02, 2005 8:07 am    Post subject: Reply with quote
im about to figure that out myself.. im following the haynes manual im not really sure yet, after im finished ill let you know what ive learned. im sure someone can help us both out with some pointers though.
PostPosted: Mon May 02, 2005 9:06 am    Post subject: Reply with quote
Well for one you lift the plunger with fuel pump on requiring
and the injectors out placed in a fuel proof container. This
requires a jumper in place of the fuel pump relay.
check the spray patterns of all the injectors then
take off the fuel return line from the firewall connector
follow it from the fuel dizzy if you run the pump for a certian
amount of time as outlined in the haynes you should get a specific
amount of fuel this will tell if alls well. though you need to see that
injector is spraying fuel like it should.
pyromjm
PostPosted: Mon May 02, 2005 9:18 am    Post subject: Reply with quote
how do you take off the fuel return line and measure the fuel coming out of there? isnt that the hard plastic fuel line that you have to heat up to remove?
PostPosted: Mon May 02, 2005 9:23 am    Post subject: Reply with quote
no its the one opposite from the one coming off the fuel filter
on the otherside of the dizzy it goes to a line that goes down under the car
along the firewall.
pyromjm
PostPosted: Mon May 02, 2005 9:25 am    Post subject: Reply with quote
on mine they both have the same plastic hose, the one from the fuel filter and the one underneith that goes to the firewall
PostPosted: Mon May 02, 2005 9:28 am    Post subject: Reply with quote
You need to get a haynes manual theres one on line though
I dont think it outlines the tests as well as the haynes
manual in your hands would. This might help though do a search
on the board.
http://www.924board.org/viewtopic.php?t=13786&highlight=fuel+pump+test
