need nut and bolt size for ball joint replacement
augidog
PostPosted: Fri Dec 10, 2004 12:06 pm    Post subject: need nut and bolt size for ball joint replacement Reply with quote
Anyone know the nut and bolt size for ball joint replacement.
I have new ball joints and they have never been changed before on the car.
PostPosted: Fri Dec 10, 2004 12:15 pm    Post subject: Reply with quote
If you are talking about the 3 bolts and nuts that attach the ball joint to the control arm, they always ship with the ball joints.
PostPosted: Fri Dec 10, 2004 12:20 pm    Post subject: Reply with quote
Mine came with grade 8.8 M7x20 bolts, nuts and lock washers (1.0 mm thread spacing).
augidog
PostPosted: Fri Dec 10, 2004 12:27 pm    Post subject: Reply with quote
no bolts recieved just joints'
Thanks, Smoothie
