POWER WINDOWS
Xenotide
PostPosted: Sun Dec 05, 2004 1:40 pm    Post subject: POWER WINDOWS Reply with quote
Hey guy I have this problem with my power windows
the motors are getting 9 volts is that normal? I have tried different switches and I have tested for voltage but the windows will just nopt go up and down. Could someone please tell me if this is a sign of dead motors or something else
1980- 924 first Porsche and Restore Project
My girl is getting painted... ABOUT TIME
PostPosted: Sun Dec 05, 2004 1:48 pm    Post subject: Reply with quote
Probably something else.
Check the power window relay (J?).
PostPosted: Sun Dec 05, 2004 2:38 pm    Post subject: Reply with quote
Hey Jason, iirc we hooked power up to the windows directly and they worked correct?
also was that 9 volts with the car running or not?
also verify that you have ground to the switch and the ground is clean.
3 928s,
CMXXXI
PostPosted: Tue Dec 07, 2004 5:48 am    Post subject: Reply with quote
The windows should be getting a nominal 12v. The window relay is not on the relay board, but is probably clipped somewhere up under dash by the firewall, perhaps on part of the heater box or ducting. Be advised that all your switches and associated wiring has to be good or else you will get wierd behavior (if any at all).
'79 Eurospec 931
CMXXXI
'79 Eurospec 931
