A/C leaks gas
kike924
PostPosted: Mon Nov 29, 2004 8:25 am    Post subject: A/C leaks gas Reply with quote
Last summer I had to rebuild my car A/C compressor because it was leaking gas
Now that the hot days are near (Southern hemisphere) It appears that again the gas is missing
Is there some special issues with our cars A/C??
do I have to put in gas every summer??
thanks in advance for your knowledge
Euro 924 1980 N/A
Daily driver + week end racer
Diesel
PostPosted: Mon Nov 29, 2004 8:49 am    Post subject: Reply with quote
What's the price of R-12 in your country?
kike924
PostPosted: Mon Nov 29, 2004 9:50 am    Post subject: Reply with quote
I donīt know the exact price but I think around 30 U$s for a full charge
Euro 924 1980 N/A
numbbers
PostPosted: Mon Nov 29, 2004 11:11 am    Post subject: Reply with quote
Check the bottom hose, where it goes into the evaporator. If you see a build-up of oil around the fitting, that is where your leak is. My 931 was leaking there. I used silicone glue to seal the fitting, and have not had to add R12 in seven years.
kike924
PostPosted: Mon Nov 29, 2004 11:13 am    Post subject: Reply with quote
Thank you for your help!!!!
Euro 924 1980 N/A
AGD931
PostPosted: Tue Nov 30, 2004 3:46 am    Post subject: Reply with quote
I had the same problem with mine, I was losing R12 every week. Turned out that the dehydrator ( black metal cylindrical container under the left headlight) was rusty.
Replaced it about 4 months ago, still blows cold air, so probably fixed it. I say that because the first diagnosis was that the compressor was dead. Ouch!!!!
Arthur
1981 931 S2
1990 E30 320i Cabrio
1979 Ford Capri Ghia
