Does anyone know....?
garthfan
PostPosted: Tue Nov 23, 2004 11:30 pm    Post subject: Does anyone know....? Reply with quote
...if the timing components (belts, rollers, tensioners, etc.) from an '87 924S 2.5 will work in an '87 944 2.5???
Thanks!
1987 924S - Was a daily driver...now it's GONE! *sniff*
1986 944 N/A Guards Red
1996 VW Jetta Grocery-Getter
1995 Saab 900S Winter-Driving-Feeling-of-Security-Vehicle
PostPosted: Wed Nov 24, 2004 1:22 am    Post subject: Reply with quote
The parts should be the same with the possible exception that the 924S may, or may not have the spring loaded timing belt tensioner (depending on when it was made, and the 87 944 should have spring loaded timing belt tensioner.
So, the 87 944 engine will probably need an extra tensioner pulley that the 924S may not have.
