Those who installed 6x9s in the rear...
Lorenzo Booker
PostPosted: Wed Sep 15, 2004 2:51 am    Post subject: Those who installed 6x9s in the rear... Reply with quote
Those who installed 6x9s in the rear, how simple was it to install them and were there any modifications needed? What type of 6x9s did yall use?I'm thinking about dropping 6x9s straight into the factory hole. Just hope that I have enough space front and back.
Magnus K
PostPosted: Mon Sep 20, 2004 6:25 pm    Post subject: Reply with quote
Errr... I done half of this, one side finished and the other is still waiting.
I had a pair of old Zachry 6x9s and tried to install them in my 924. The backspacing and space around the 4x6 factory hole wasn't really enough so I had to make adapters to make the speaker fit in place. Looks like this:
http://www.shell.linux.se/magnusk/projekt/bilder_20040731_hogtalare.html?number=03
And no, there wasn't enough space from the speaker to the quarter panel either so the panels will have to be modified...
Note: In my 924 the PO had tried to install 5 1/4 inch speakers in the 4x6 inch hole... Simply by cutting out a bit of body metal... The hole looked like this:
http://www.shell.linux.se/magnusk/projekt/bilder_20040731_hogtalare.html?number=01
And the quarter panels is in really bad shape so I simply cut them and tried to make them fit over the speaker. Really ugly work with a knife and black duct tape... Heck, it's just a track day car...
/Magnus K
Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake...
Latka
PostPosted: Sat Nov 27, 2004 11:38 am    Post subject: Reply with quote
My buddy and I put 2 pairs of Alpine 6x9s in my 87 S. After doing the rear speakers...if I ever had to do it again I'd just take it to a stereo shop and let them deal with it. It was a HUGE pain in the butt. Some say that you can pop the side rear window out easily, but I wasn't willing to try it and risk smashing the window into 4,000,000 pieces.
-Andy
Llamaguy
PostPosted: Sun Nov 28, 2004 2:13 pm    Post subject: Reply with quote
So do 6x9 fit without modification? I already changed them once with no problem
1987 924S Guards Red
1997 Suzuki Tl1000 Supersport
CMXXXI
PostPosted: Sun Nov 28, 2004 3:30 pm    Post subject: Reply with quote
Negative. Only 4x6 will fit without modification. If you changed them one time already, you should have seen the spacing and cut-out limitiations... The sheet metal supporting the rear quarter panel speakers has adequate "excess" to cut your own holes, but it's labor intensive. You may have depth clearance problems to fit any 6x9 behind the OEM fascia.
'79 Eurospec 931
percy
PostPosted: Thu Dec 02, 2004 3:56 am    Post subject: Reply with quote
The stereo shop wil probably have to smash your rear windows too - at least they did mine.
I only know because I found a tiny particle of glass months later.
They did a really good tidy up job and thought that what I didn't know, I couldn't grieve over.
Thinking back they were very keen that I should "go and get some lunch and not come back for 2 hours."
Llamaguy
PostPosted: Fri Dec 03, 2004 1:41 pm    Post subject: Reply with quote
yeah, I found a ton of glass behind the panel, but it might have been from a break in or something
