Possible Hood Strut Mounting Points
tj924
PostPosted: Sun Nov 07, 2004 5:44 pm    Post subject: Possible Hood Strut Mounting Points Reply with quote
In this pic
where the arrows are pointing to, are they hood strut mounting points? They appear to be factory rather than add-on. Could that be right?
TJ
Silver '82 924 NA 5-Speed Manual
My924gtc
PostPosted: Sun Nov 07, 2004 9:16 pm    Post subject: Reply with quote
Those are indeed factory hood strut mounting points you've got there.
BTW-have your wheels shown up yet?
MJ
'81 924 2.0L T
'82 924 2.3L SC/EFI <---online fall '06
Sponsor of the 944 Cup and Super Cup
Sponsor of the "2006 Battle in the Badlands"
tj924
PostPosted: Sun Nov 07, 2004 9:24 pm    Post subject: Reply with quote
Does that mean the car would originally have come with hood struts? Was that an option or standard equipment on an '82?
No wheels yet. Will have been 4 weeks this Tuesday (9 November). You shipped Tuesday 12 October (my time) I think. 4 to 6 weeks is what comes to mind for an ETA.
TJ
My924gtc
PostPosted: Sun Nov 07, 2004 9:42 pm    Post subject: Reply with quote
Not sure if it was standard equipment in '82 but I have not seen an '82 that does not have struts.
Does the car have a prop rod too? If so, I would say that the struts were an option. My '82, which appears to be identicle to yours BTW, had struts but no rod and no signs of one that was removed.
MJ
'81 924 2.0L T
tj924
PostPosted: Sun Nov 07, 2004 9:46 pm    Post subject: Reply with quote
Yep, it has a rod
TJ
924guy
PostPosted: Mon Nov 08, 2004 12:23 am    Post subject: Reply with quote
all the late 81/82 models ive seen have strut mounts, they did not come with hood struts however. my guess is that it because they were also starting to produce 944's at that time, same hood so we got the later spec'd hoods..We didnt get the struts because they had to relocate the fuel lines in the 944's , in our cars, the struts can and will rub the fuel lines on one side if you install them without slightly bending out the fuel lines so theyre out of the way.. I also took a piece of rubber hose, split it longitudally,stuck it over my fuel line and used it as a buffer for additional protection against rubbing, just in case. Last thing you want is to rupture that fuel line, so use care if you do this.... my hood also had an accomodation for struts, so it was a simple matter of just buying a set of early 944 hood struts and popping them on.. work great,and you dont have the hood sag on one side when you open it like with the rod. but i cant seem to find a set that will last more than a year or two, so im replacing them more than id like.. but i left the hood prop rod in as well, when they go i have a built in back up..
Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha
waarsen
PostPosted: Thu Nov 11, 2004 8:15 am    Post subject: get your gassprings/struts at www.springmasters.nl Reply with quote
hey guys if you need gaasprings for your porsche go to www.springmasters.nl call them, the owner has a 944 and had a 924 so he will know which kind you need.....if you live in america and need gassprings email me at america@springmasters.nl
