Two questions......
Kenodog
PostPosted: Thu Oct 28, 2004 7:07 am    Post subject: Two questions...... Reply with quote
#1) Can anyone tell me the minimum thickness for a rear brake rotor on a 931.It's not stamped on the part like usual.
#2) Can anyone tell me if Bilsteins are adjustable by turning the allen keyed shaft that sticks up thru the strut tower?If so what way would I turn it to slow the rebound ?
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
Porschephile
PostPosted: Thu Oct 28, 2004 7:21 am    Post subject: Reply with quote
I'm pretty sure the billstiens are not adjustable. I beleive that allen key is to help remove them, as the shaft turns with the nut when removing it.
As for the brake rotor question, I have no idea.
werd B.
sandgroper
PostPosted: Thu Oct 28, 2004 7:46 am    Post subject: Reply with quote
keno,the tech spec book says 19.2mm minimum thickness for the rear disc,says they are 20mm new.
PostPosted: Thu Oct 28, 2004 3:04 pm    Post subject: Reply with quote
bilsteins are none adjustable.
3 928s,
