Joined: 29 Jul 2001 Posts: 9121 Location: Royal Oak, MI, USA
Posted: Sun Oct 24, 2004 11:05 pm Post subject: Shift Lights |
One person asked, and I thought perhaps others migt be interested in the answer as well, about my shift light setup (in the racecar):
http://vaughanscott.com/construction.htm#MYCHRON3
I am running the AIM MyChron3 Gold XG Auto Data acquisition system with dash display. It tracks speed, RPM, lap times, lateral G's, calculates gear, and will also monitor up to 4 other input signals; we typically run longitudinal G's, yaw rate, oil pressure and water temp (but can switch them out at will). For example, for dyno tuning runs, we'll likely run all 4 EGT's at once to view cylinder-to-cylinder mixture differences.
But it's very expensive, designed for full-on racecars; they start at $350, and mine costs over $900.
If you're just simply looking to add some gauges and shift lights, buy the VDO gauges, and a set of inexpensive shift lights. DKS Electronics makes some nice little programmable ones; their website's flaky at the moment, but I've sent them an email and they're at:
http://www.dkselectronics.com/
$120-145 is what their units cost.
Here's the cached version of their main page:
http://216.109.117.135/search/cache?p=DKS+Electronics&ei=UTF-8&fl=0&u=www.sequentialshiftlight.com/&w=dks+electronics&d=1EB50C7AC9&icp=1&.intl=us
To jump past the non-functional first page, here's the photos of their shift lights:
http://www.dkselectronics.com/photogallery/default.htm
 _________________ Vaughan Scott
Llamaguy
Posted: Wed Oct 27, 2004 2:04 am Post subject: |
I guess this kinda falls in this topic, what is the little arrow in the middle of the tach? _________________ 1987 924S Guards Red
924guy
Posted: Wed Oct 27, 2004 3:19 am Post subject: |
hmmm, seems to me this should be pretty easy to makle a simple version, using variable resistors or adjustable pots... assuming the tach feed wire increases voltage as the rpms go up.. but as the old saying goes.. "sure you can make one yourself..the question is "Will you??" "  _________________ Eric
78 924
82 931 SE "smokey"
99' VehiCross
Y2K Honda Insight
Performance by Pasha |
