gaskets heat exchanger
PostPosted: Sun Oct 24, 2004 2:11 am    Post subject: gaskets heat exchanger Reply with quote
Need heat and my heater box isnt to bad though sometime
I would like to get an afte rmarket high output heater. For now
though replacing the 2 heater core gasket seems to be the thing to do
I was wonderen if theres any other porsches that use the same
heat exchanger.. Im gonna check the size of them and check a hardware place or 2. How about a VW rabbit or something. These are the 2 round
washer type hard rubber things that are inbetween the coupler and exchanger held in place with 3 bolts.. mines leaking Im thinking new
bolts with washers lock nuts and 2 compatable sized rubber things
and it might hold. "Its Oh so cold in the middle of the road and the heater dont work."
