Solution?????
xpernet
PostPosted: Fri Oct 08, 2004 10:34 pm    Post subject: Solution????? Reply with quote
Hey Guys!
I think that i know why my 924 has lots of electrical problems. Well, since we have bought the 924, we replaced the spark plugs, but we didnt have enough time to change the distributor cap, rotor arm, spark plug wires, etc... So when i turn on the car, and press the pedal, the muffler gives this shuttering sound, and it disappears, at a certain point. While i press the pedal, the gas gauge flickers, voltage increases, and today i tried on the Fan, and it's speed increases as i hit the pedal! The car seems to use alot of voltage at idle, and when i hit the pedal, Mr.Alternator gives good voltage to every thing, or is Mr.Alternator going to die?
Also, is the distributor cap from a VW or a BMW?? Rotor Arm??? The word porsche in car stores, signify an increase of 30% or more on the Price Tag
Thanx In Advance!!!
xpernet
1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
