Sunroof leaks
bush0117
PostPosted: Thu Sep 30, 2004 2:17 pm    Post subject: Sunroof leaks Reply with quote
Okay my sunroof leaks on my 77 924. The guy that had it before me had it silcone in. And I clean all that out and clean the drain hoses. Put a new seal in and new latchs on it. But it still leaks when it rains alot or if I'm washing the car. So want am I missing? I thought about just having it welded up. But I thought I shoot it cross you guys before doing that.
Thanks,
Jason Bush
My924gtc
PostPosted: Thu Sep 30, 2004 2:30 pm    Post subject: Reply with quote
Stupid question but did you replace both seals (i.e. roof and panel)?
MJ
'81 924 2.0L T
Sponsor of the "2006 Battle in the Badlands"
bush0117
PostPosted: Thu Sep 30, 2004 2:42 pm    Post subject: Reply with quote
Okay I thought there is one seal. I bought it from Performance Products. And it went on the car. Now if there is a second one where do I get it? Same place and does it go on the sunroof? Thanks for the quick response.
Jason Bush
My924gtc
PostPosted: Thu Sep 30, 2004 2:48 pm    Post subject: Reply with quote
Yep, goes around the outer edge of the sunroof panel. It's the cheaper of the 2 also, so the painful part is over. Should be around $18.00 from PP if I remember correctly.
MJ
'81 924 2.0L T
PostPosted: Thu Sep 30, 2004 2:53 pm    Post subject: Reply with quote
also you cannot weld in that roof, as the sunroof panel isnt steel
3 928s,
PostPosted: Thu Sep 30, 2004 4:39 pm    Post subject: Reply with quote
The seal that goes on the sunroof is the more expensive part, and the one that needs to be replaced, if the sunroof is leaking.
The cheaper piece that goes on the edge of the hole in the roof, is more a decorative trim piece (holds the edges of the headliner in place)than a seal.
