Chrenan
Posted: Tue Sep 21, 2004 12:32 am Post subject: Pulled Engine Pictures |
Pulled the engine from the parts car I picked up, took about 4 hours, not nearly as bad a job as I had expected...
 _________________ 1987 951 - M193 Version for Japan |
Jazzerpet
Posted: Tue Sep 21, 2004 2:33 am Post subject: |
Hay that looks just like my engine stand.
I done that not 2 days ago but I pulled the 4 bolts from the torque tube instead. It all started to replace the clutch but ended up pulling apart the whole thing wile cleaning it. Good thing I did, I found the #2 ring on the #4 cylinder busted. Looks like the PO done a rebuild recently. I think he may have even put new pistons in. Must not have checked the ring gap before assembly. The cylinder walls were ok so I redone the crosshatching replaced the rings and reassembled. Hope to have it on the road by the end of the week.
Good luck with your project. Jim _________________ 1980 931
1985 ½ 944
Member of the “Omaha Crew” |
CMXXXI
Posted: Tue Sep 21, 2004 3:08 am Post subject: |
Wasn't that fun!!
Check that right side motor mount before you reinstall. There is a good chance that the spring inside of it is broken. _________________ '79 Eurospec 931 |
Neil924
Posted: Tue Sep 21, 2004 3:15 am Post subject: |
In your 1st picture, is that a laser?
I wish my car had one.  |
Chrenan
Posted: Tue Sep 21, 2004 3:17 am Post subject: |
Yeah, it was kind of fun. We were thinking of pulling the 4 bolts at the torque tube as well, but decided to go the conventional route. This engine will be on a stand for a bit while I tinker and learn, break it down and rebuild and then install it in my 924. The body of the car it came out of has a few more items I will strip off before it goes to the scrap heap. _________________ 1987 951 - M193 Version for Japan |
Chrenan
Posted: Tue Sep 21, 2004 3:19 am Post subject: |
Neil,
Laser? _________________ 1987 951 - M193 Version for Japan |
Neil924
Posted: Tue Sep 21, 2004 6:34 am Post subject: |
| Chrenan wrote: | Neil,
Laser? |
In the 1st picture, to the right of the jackstand, the laser, it looks like the one in Startrak, that's on the front of thier ships. |
Chrenan
Posted: Tue Sep 21, 2004 1:05 pm Post subject: |
I guess it does. Never looked at it that way but you're right. _________________ 1987 951 - M193 Version for Japan |
Posted: Wed Sep 22, 2004 10:18 am Post subject: |
Cool what are you gonna do. Fix it up I hope. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Chrenan
Posted: Thu Sep 23, 2004 1:26 am Post subject: |
Yeah, fix up the engine is the plan, the body itself is going to a scrap yard unless smoeone in Edmonton wants to take it for free. I'd like to rebuild the engine slowly over the next few years, a bit of a learning exercise. _________________ 1987 951 - M193 Version for Japan |
