xpernet
Joined: 07 Apr 2004 Posts: 414 Location: Kitchener, Ontario Canada
Posted: Sat Sep 04, 2004 3:53 am Post subject: Simple Questions |
Hey!
My car is missing the blinker reset piece. Which car other than a Porsche can i get one from. We dont have much porsches in scrap yards.
Also, my wipers wont change speed. I mean, when i change from one speed to another, my wiper is still constant.
Thanx guys!
xpernet _________________ 1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
CMXXXI
Posted: Sat Sep 04, 2004 4:19 am Post subject: |
The turn signal cancel happens because a "prong" on the back-side of the steering wheel hits a cam in the turn signal mechanism. Either this prong has worn or broken off, or the cam/spring mechanism is either worn, broken or out of alignment. In any case, you will have to pull the steering wheel to get at the parts involved to figure out exactly which mechanical part needs attention.
I'm not sure, but I think the speed (and "parking") of the w/s wipers is all controlled by the w/s wiper relay, located above your main fuse panel. I don't have a reference handy as to which relay controls what function. _________________ '79 Eurospec 931 |
Eturbo924
Posted: Sat Sep 04, 2004 4:26 am Post subject: |
In the 1977 replace the relay as the other poster said.
I am sure some one here has the part you need.
Eric _________________ 1982 924
1992 968
2003 C4S
E-mail me for parts you need!
Drive Fast! |
