HappyPuppy
Joined: 04 Jan 2003 Posts: 114 Location: Chattanooga, TN USA
Posted: Sat Mar 20, 2004 3:59 pm Post subject: Let Me Try this again...V6 Audi Swap Idea |
I've been looking around for more swap ideas, when I came to a realization. The 01E 6-speed Audi Transaxle was used in the 2.7L V6 S6, right? Well, judging from the pics of one of these trannies, it looks to have the identical bolt pattern and spacing as the 924 bellhousing. So the REAL question is, does anyone know for certain if the other Audi engines (like the V6 and V8 ones) would not fit? 'Cuz I have a hunch they just might...
cya _________________ My frequent desire to perform violent acts on select other drivers is not road rage; it is simply preemptory self-defense. |
HappyPuppy
Posted: Tue Mar 30, 2004 1:38 pm Post subject: |
Can no one come up with at least a guess? Not even our engine swapping mentor CBass? Wow... _________________ My frequent desire to perform violent acts on select other drivers is not road rage; it is simply preemptory self-defense. |
Neil924
Posted: Tue Mar 30, 2004 2:10 pm Post subject: |
I barely pump my own gas {after I left the station without my gas cap, swishing litres of gas all over the road and the side of my car}.
I can be soo stupid!  |
Posted: Tue Mar 30, 2004 2:14 pm Post subject: |
it is VERY possible that it may bolt up to the stock bellhousing of the 924 noone will know for sure until they get a block and a 924 bellhousing and try _________________ 3 928s, |
ponchojuan
Posted: Sun Aug 08, 2004 11:26 pm Post subject: |
| HEy, did this idea ever go anywhere? I've considered a similar idea. |
jody in georgia
Posted: Mon Aug 09, 2004 11:43 am Post subject: transplant |
| as long as the block will bolt up and the flywheel bolt pattern will accept the flywheel from your porsche or who knows it may even be the same spline shaft it should fit. one thing to check is motor mount location . I pull alot of motors and I know most front wheel drive blocks use different mount locations than rear wheel . |
ponchojuan
Posted: Fri Aug 13, 2004 11:27 pm Post subject: |
| Wonder where we can get the specs to compare. Does anyone have the spline and bellhousing mesurements for the 924 2.0L? |
