most likely a fuel problem
ProudGecko
PostPosted: Fri May 21, 2004 2:41 pm    Post subject: most likely a fuel problem Reply with quote
Ok so here's the deal. My car starts up rough when cold, sometimes it'll start and then die unless I give it some gas at which point it will idle just fine. It also has a severe hesitation when the engine is cold at low rpm's, it will nearly die sometimes in first or second gear. I have also noticed a slight hesitation that sometimes occurs when accelerating, and this is all the time at any engine temperature. My fuel efficiency seems to have also decreased considerably, and also the car wouldn't start if the temperature dropped below about 25 deg F. I'm pretty sure it's fuel related, I'm going to try to check the engine temp sensor tomorrow and see what that tells me but I don't think it's the problem. Any clues as to what could be the problem?
Thanks
1988 Porsche 924S
1986 Kawasaki Concurs ZG1000
1984 Mercedes 190D
1973 Honda CB500
Sleykin
PostPosted: Sat May 22, 2004 5:33 am    Post subject: Reply with quote
My first guess would be a bad or mis-adjusted TPS
Glenn Neff
Medford, OR
87' 924S
ProudGecko
PostPosted: Sat May 22, 2004 5:45 am    Post subject: Reply with quote
I can hear it clicking when I move the throttle so I know that mechanically it is working, but i don't think i've actually tested it yet
1988 Porsche 924S
1984 Mercedes 190D
1973 Honda CB500
Sleykin
PostPosted: Sun May 23, 2004 1:57 am    Post subject: Reply with quote
The clicking is not real useful. It just means the parts are still there. Use an ohmmeter and verify less than 1 ohm resistance. You might try running some injector cleaner through your tank too. There is a great writup on Clark's garage in the shop manual for troubleshooting this area.
Glenn Neff
Medford, OR
87' 924S
ProudGecko
PostPosted: Sun Jul 11, 2004 5:00 pm    Post subject: Reply with quote
ok finally got around to testing the TPS and it works just fine, i tested it both at the DME plug and the actual sensor plug. I've also tested the engine temperature sensor and it appears to be working just fine as well. Anyone have any ideas as to what else the problem may be? Oh and I've been running injector cleaner through it for awhile with little to no improvement and I did replace the fuel filter as well with again no improvement.
1988 Porsche 924S
1984 Mercedes 190D
1973 Honda CB500
Sleykin
PostPosted: Mon Jul 12, 2004 2:32 am    Post subject: Reply with quote
Ok ... so much for the easy stuff What do your plugs look like? Do you have the fuel economy guage? It can give you some clues. I would lean more to ignition related things at this point. Mine has developed a slight hesitation when cold at about 1500 RPM accelerating in first and second gear. I think I need to clean my speed and reference sensors ... when I get around to it. So far it only does the hesitation thing first go out. After driving a block or so it is fine.
Glenn Neff
Medford, OR
87' 924S
ProudGecko
PostPosted: Mon Jul 12, 2004 3:39 am    Post subject: Reply with quote
my plugs are fine, and the speed and reference sensors are clean. I cleaned them when I replaced the clutch a couple of months ago. Mine does the same thing, after a minute or two of driving it drives pretty much normal. And no i don't have the fuel economy guage
1988 Porsche 924S
1984 Mercedes 190D
1973 Honda CB500
PostPosted: Mon Jul 12, 2004 3:59 am    Post subject: Reply with quote
check your fuel pressure regulator or ust replace it
3 928s,
Sleykin
PostPosted: Mon Jul 12, 2004 5:44 am    Post subject: Reply with quote
I meant to read the plugs for a general idea of how your mixture is set. If you are happy with everything in the ignition then yes the next check would be fuel pressure and volume and a careful check for vacuum leaks.
Glenn Neff
Medford, OR
87' 924S
ProudGecko
PostPosted: Mon Aug 09, 2004 2:35 pm    Post subject: Reply with quote
ok so after some issues with trying to order a fuel pressure regulator, i finally got a new one and installed it. It certainly didn't fix my problem although i think it has smoothed out the engine a bit and it seems to have helped my fuel economy. So what should i be checking next?
1988 Porsche 924S
1984 Mercedes 190D
1973 Honda CB500
PostPosted: Tue Aug 10, 2004 8:27 am    Post subject: Reply with quote
I'd test the AFM next.
Sleykin
PostPosted: Tue Aug 10, 2004 9:30 am    Post subject: Reply with quote
What did you see when you pulled the spark plugs?
Glenn Neff
Medford, OR
87' 924S
Manning
PostPosted: Tue Aug 10, 2004 10:56 am    Post subject: Reply with quote
Oh so many things it could be.
Have you checked all of the vacuum lines to make sure they are attached and not split? Is the intake boot firmly attached to the throttle body and AFM? Have you had the manifold off and checked the ISV? How about the larger hoses, like the ones to the ISV or the oil mist seperator, are they still pliable and make seal to the associated nipples?
I had a rough idle and cold start/idle hunting issue and replacing all those bits, which were realitively cheap except for the ISV, mostly cured the rough idle and got rid of the cold idle hunting issue. Getting rid of the MSDS cone filter cured it completely.
Michael Manning
1988 924S Undergoing weight loss program
