crunchie 57
Joined: 18 Mar 2004 Posts: 117 Location: Brisbane Australia
Posted: Sat Aug 07, 2004 10:04 pm Post subject: wheel alinement for 81 931 |
Hi guys can anyone give me the toe in/out spec for the front of my 81 931
as I have just changed the right hand tierod cup and ball. I intend takeing it to the shop to get it done correctly (I hope) but just want to set it up close for now so I can drive it in there. Also the book says to set the rack at center (with lock pin ) then set gap from shoulder of cup stop ring to housing at 65mm +/- .5mm If I do this the cup is only on by about four threads.... hope someone can enlighten me .. _________________ 78 924 N/A with 944 body kit (love this car)
79 924 NA - track car
81 924 Auto with 6V Buick |
augidog
Posted: Sat Aug 07, 2004 11:59 pm Post subject: |
I hope this helps.
http://members.localnet.com/~augidog/Untitled-1.gif
The right side cup is measured to inside the steering arm-or to the point the stop ring will actually stop. I hope that makes sense- I did the same thing originally. _________________ 1978 924 95 mile daily driver.
crunchie 57
Posted: Sun Aug 08, 2004 8:22 am Post subject: |
Thanks augidog
My car is a right hand drive but just revese the pic. I did measure from the edge off the tube . will go and resett thanks for your help
do you happen to knoe the toe in/out setting ? _________________ 78 924 N/A with 944 body kit (love this car)
augidog
Posted: Sun Aug 08, 2004 11:20 am Post subject: |
http://www.924.org/techsection/10suspension.htm#2%20-%20Alignments
http://www.vtr.org/maintain/diy-alignment.html
If you want to give it a shot yourself, use the fishing line method for toe.
The front tires are 3/4 wider in tracking on each side, so your fishing line will be 3/4 further from the back rim on each side.
The toe in- front 1/32 to 1/8- -------the back to 0
I was told to set the front camber to -1 --------the back to -1.5
I'm not racing ---just going to work.
crunchie 57
Posted: Sun Aug 08, 2004 1:40 pm Post subject: |
thanks again augidog
I have got the rack sorted, and made up a guage for the toe in so I am off to set them. Thanks again you have been a great help  _________________ 78 924 N/A with 944 body kit (love this car)
