Posted: Sun Aug 08, 2004 8:32 am Post subject: Pressure Bleeder is Great! |
Replaced my clutch master cylinder today, and all brake pads, and flushed and changed my brake fluid.
This made it easy:
All I did was install the master cylinder, hooked up the bleeder, jacked up the front of the car, removed the starter, opened the slave bleeder screw, left it flow about 30 seconds until the fluid was clean and bubble free. Checked the clutch pedal, it worked fine the first push! I didn't even prime the master cylinder.
While I had it hooked up, I replaced all brake pads with Mintex silver, and changed the brake fluid by opening each bleeder valve in order. NO PUMPING THE PEDAL....SWEET! |
