Removing axles from tranny
Chrenan
PostPosted: Fri Jul 30, 2004 1:01 am    Post subject: Removing axles from tranny Reply with quote
Removing axles from tranny:
Do I need the spline key or can I just use an hex (allan) key?
What size spline key do I need?
What size hex key will work?
(I probably have the right size hex key, but I would have to buy the spline key)
Fuzzbeaner
PostPosted: Fri Jul 30, 2004 1:13 am    Post subject: Reply with quote
Just had this problem a week ago!
What you need is a 12 point, 8mm star bit.
Yea, weird huh? The guys at Consumer Auto Parts will give you a weird look, but they had them at my local one.
8 bucks for a set of 4. (generic)
Good luck!
-Jeff
A Ravaged '77 924 (Electric Conversion in Progress)
Chrenan
PostPosted: Fri Jul 30, 2004 1:17 am    Post subject: Reply with quote
Thanks Jeff, much appreciated...
Doodle
PostPosted: Mon Aug 02, 2004 6:41 am    Post subject: Reply with quote
Check Canadian Tire. I think it's their Lisle line of tools. About $15.00 Can. for 4 different sizes. Not the best quality but good enough too get the job done. Whatever tool you use be sure to meticulously clean the screw heads before engaging the tool.
Doodle
Pre 77.5 Mars Red
PostPosted: Mon Aug 02, 2004 7:11 am    Post subject: Reply with quote
You can extend the life of the 12pt bits and bolt heads with Vise-Grip pliers. Loosen the bolts with the Vise-Grips on the outside of the bolt heads, then they can be easily removed the rest of the way without damage with the 12pt bit or bolt head sockets. Then with the bolts removed you can clean the bolt head sockets more easily, then use the 12pt again to reinstall and torque 'em.
Also - once there's some wear on the bit you can grind/cut off ~1/8" from the end and get some more use out of it.
Chrenan
PostPosted: Tue Aug 03, 2004 9:04 am    Post subject: Reply with quote
Good tips guys, looks like Canadian Tire will be stealing more of my money...
