timstar924
Posted: Fri Jul 30, 2004 5:43 pm Post subject: replacing the muffler? |
there is a nice size rust hole on my muffler and it leaks water so i don't think my car will pass aircare to get insurance because of this. can someone tell me where i can get a new muffler, should i go ask napa or lordco? and what else do i need other than the muffler to install it? Also i might be wrong but isn't the muffler welded to the car? i wan to do this mysel if it is an easy task.
thanks. |
Posted: Fri Jul 30, 2004 5:59 pm Post subject: |
Unless you can actually buy a complete exhaust (in which case it's just a matter of bolting it on), IMHO you are best to get a shop to do this.
A basic complete exhaust system should be quite cheap; I got a new exhaust, from the headers back, for my (now deceased) '77 BMW 320i for AU$180 -fitted. And just welding in a new muffler shouldn't be a big deal.
I don't know about the U.S.-spec 924 (I assume that's what you've got), but I doubt it's anything fancy. But they may run catalytic converters (which ours don't), so it may be more expensive to replace the entire exhaust.
But once, when my exhaust broke on the old Bimmer, I got a shop to weld in a new piece for AU$25! The exhaust pipe before the first muffler literally rusted through, and split in half! Hell of a noise Sounded like a rally car I had to drive it back from Gladstone to Brisbane the next day (about 650km/400 miles) so I had to get it fixed! They were really good, just cut out the rusted bit and welded a new bit in... of course, I eventually had to get it all replaced, as above.
I've got a stainless-steel jobbie on the Porker, so it's not been a problem. _________________ '80 924 Turbo |
timstar924
Posted: Fri Jul 30, 2004 6:09 pm Post subject: |
| ok tanks should i get the muffler myself and take it to the shop or just get them to order it. i went to lordco and they said there is only one company that makes a exhaust system for my car and he said the whole thing form engine to muffler is 1000 cdn, its really expensive. i'm guessing muffler will be at least 150 bucks and installing it probable another 60-80 bucsk. |
Posted: Fri Jul 30, 2004 6:20 pm Post subject: |
You can get an ANSA OEM style cat back final muffler (one piece from the cat to the tailpipe) for between $150-$200 from many mail order shops.
Usually what dies first is the rear muffler/resonator. If the first of the exhaust system is still good, you should be able to take the car to a local muffler shop, and get a generic muffler welded into place for $50-$75. |
CMXXXI
Posted: Sat Jul 31, 2004 3:18 am Post subject: |
Don't places like Midas and Meineke still give lifetime replacements for parts and labor? I recall someone here on the Board saying that they went that route, and have gotten 2-3 free replacements over the years. May not be the least expensive approach if it's a one-time shot, but over the years it could easily pay off. _________________ '79 Eurospec 931 |
Posted: Sat Jul 31, 2004 9:45 am Post subject: |
I think Stuj2 is the one with the Midas exhaust. Seems to me that he has boasted several times that he just goes in every couple of years when it rusts out and Midas replaces it for free.
Here is CA, we don't have the rust problem that the guys in the Northeast or East Coast have. I tried Midas once for a replacement exhaust, but their price was like close to $500. I got a new ANSA OEM 924 exhaust from the Pomona Swapmeet for $40 instead. It isn't as well made as the original German part, nor are the materials as good. But it is much lighter, has been on the car for six years, and still looks and sounds like new. |
bryanc
Joined: 27 Feb 2003 Posts: 233 Location: San Antonio, Texas
Posted: Sat Jul 31, 2004 11:56 am Post subject: |
IMHO the muffler for free thing is a scam. I had a car I took back to the muffler shop and they told me the engine had backfired into the muffler causing it to fail. I asked them to show me and they just pointed at a hole in the muffler so I asked for the manager. He said maybe it wasn't a backfire problem and he would be glad to provide a replacement muffler for FREE! oh yea he just had to charge me for installation, 2 hangers, the exhaust tip and a couple of clamps. With the new price list this cost $4 less than the original installation. _________________ '84 944
I'd rather have a bottle in front a' me than a frontal lobotomy
Tom Waits |
Posted: Sat Jul 31, 2004 12:35 pm Post subject: |
Or pm a guy by the name of Lizard here on this board he knows lordco and might even help you with the install if you guys are close enough. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Sat Jul 31, 2004 3:13 pm Post subject: |
this is a tricky question, if you dont have a welder DONT do your own exhaust, there is only 1 way to do exhaust imo and it is not with clamps, the clamps distort the steel and they leak past it in a short period of time, I would recommend that if you dont have a good discount at lordco or NAPA that you just go to Midas Muffler and TELL them that you want the to replace the MUFFLER only on your car, at shops up here you must be SPECIFIC with what you want them to do or you will get walked over, so go to midas and say I am needing to have a replacement muffler put on and tell them you will be needing them to supply the muffler for you as well as the tailpipe (piece coming off the muffler) and you can pick whatever piece you want or just have a piece of pipe added onto the end, but if they try to get you to replace other parts tell them NO, JUST the muffler.
I could do the muffler if you picked it up as well as show you a ton of other stuff on the car, but you would have to get it to my place out in lytton which is about 3 hours away from Richmond so it is abit of a hike. _________________ 3 928s, |
timstar924
Posted: Sat Jul 31, 2004 3:29 pm Post subject: |
| Lizard i'm going to insure my car tommorow cus i have too. aug 1st is when the aircare expires and i know it won't pass because of the muffler and maybe other things. i want to insure it so i can get some things fixed at a shop, like my door and clutch cable adjusted. i don't know when I can drive it cus my roof isn't painted yet, and i have to put the interior back together. IF you are in richmond we can meet me. i pmed you my cell last time. |
Vince Ponz
Posted: Sun Aug 01, 2004 12:18 am Post subject: |
Weld it on. It will shake loose in the long run. I had mine shake loose twice and at the header location. Welded a tab on the header and no more problems.
Welding avoides leaks at the joints. _________________ "Never let them see you sweat"
77.5 924 modified track car
79 931 Euro stock
88 924S SE
87 911 Targa stock |
