Removing a-pilar upholstery and Gas Pedal
Bassmaniac
PostPosted: Sun Jul 18, 2004 1:59 am    Post subject: Removing a-pilar upholstery and Gas Pedal Reply with quote
Iīm stripping out my car for painting, and need to remove the A pilar and the Gas pedal. I already unscrewed the a-pilars, but something still holding the no the upper side, I donīt now in which direction I should pull/push it.
The gas pedal is another mistery, I want to remove the front carpet and I donīt see how it should como off, iīts screwed to the floor?
Iasca SQ judge / Installer
Bassmaniac
PostPosted: Sun Jul 18, 2004 9:51 am    Post subject: Reply with quote
thanks for looking. IU just find out that there was a fourht screw on the top sidewise that somebody put in in the pass.
Magnus K
PostPosted: Mon Jul 19, 2004 12:43 am    Post subject: Reply with quote
The gas pedal:
IIRC it's mounted on two bolts that are welded into the floor pan. Should be two nuts holding the gas pedal to the two bolts.
Hope that helped you a bit?
Regards
Magnus
Another curious Swede...
Asleep in Sweden, Europe, when you US guys are awake...
Bassmaniac
PostPosted: Mon Jul 19, 2004 1:26 pm    Post subject: Reply with quote
Thnaks. Job done. Car already departerd for painting.
