$49 welder
wdb
PostPosted: Tue Jul 13, 2004 11:08 pm    Post subject: $49 welder Reply with quote
anyone know if this would work for light gauge stuff , exhaust,body panel rust repair work , etc .
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=33224
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=55060
Alex Roy
PostPosted: Wed Jul 14, 2004 3:43 am    Post subject: Reply with quote
stick A/C welder, would work, but not ideal for working on sheet metal or body parts. You'd be best off with a wire feed, or mig. Harbor freight sells spot welders too....that'd be best for body work.
PostPosted: Wed Jul 14, 2004 5:16 am    Post subject: Reply with quote
I started with a "Solid-Ox" welder from Kmart. It was an underpowered novelty item, but I had some fun with it as a young lad.
Next I got a Sears 200Amp AC Arc welder (stick welder) that ran on 240V. Range was limited since it had to be run from a special 240V, 50A circuit. It was really meant for heavier structural parts like frames and bumper brackets, but you were supposed to be able to do lighter work on sheet metal and the like with stich welder and spot welder attachments, but I didn't have great luck and didn't like working with them. Also - a major pain in the A is getting the arc started with an AC stick welder especially when working with lighter materials because the rod tends to get stuck to the work until you get the amp setting and technique just right. Set way too low you just get useless sparks, set higher, but still too low your rod gets stuck to the work (the welding rod), set too high and you're burning holes through the material.
Having had all the fun I could stand with the stick welder, I went for a wire fed mig/flux welder. It runs off a 120V, 20A circuit so I didn't have to rewire the house for it and I have a 10 gauge extension cord that extends the range another 50'. By changing tips, it will accept wire of different thickness and can be used as a mig welder along with a bottle of the appropriate gas (CO2, Argon, CO2+Argon, etc.) and with the correct wire, weld steel, stainless steel, aluminum or it can be used without gas with flux-core wire. It's good for everything from sheet metal to approx 1/4" steel. Still has to be set correctly - both wire feed speed and amperage, but it's way easier to get the arc started and the weld flowing than with an AC stick welder.
There's also a product from Alumiweld that looks interesting for sheet metal fusing. Racing used Swedens' equivalent of Alumiweld's product for fusing aluminum to fabricate his intake manifold, but they also have something for sheet steel. It works with just a propane torch and should be good to eliminate warpage which is commonly a problem when welding sheet metal.
A dedicated spot welder would also be good for sheet metal as Alex mentioned and would minimise the warpage problem.
As far as the extra-low priced 120V AC stick welders like in that one link, I've only heard to avoid them, but I don't know if the people saying that were talking from hearsay or first hand experience.
PostPosted: Wed Jul 14, 2004 5:50 am    Post subject: Reply with quote
What a 49.00 dollar welder id stay away from it..smoothies right you want to go with a low cost wire feed and get the argon goin, wire feed is much easier.
Sleykin
PostPosted: Wed Jul 14, 2004 10:52 am    Post subject: Reply with quote
I don't like to pay for frustration That is exactly what you would be doing with a $49 special from HF. One of the guys at work bought one and it is useable if you are already good with AC SMAW. Go down to a good welding supply house and try out a few of their machines or take a class. All MIG welders are not created equal. I had a cheap MIG for a few years and kept going back to stick or OA. I bought a Miller 175 and got rid of the buzz box, and rarely use the gas for anything but cutting. I also have a 350 amp AC/DC Miller with a TIG box that will weld about anything ... but it takes so long to set it up and connect the water etc I rarely use it either.
Probably if you are only doing body work a good O/A setup would be the least initial cost and most versatile tool. Check Pawn shops and the nickle for a used set and no matter what ya get plan to spend some time learning to use it and burning up a lot of material before you see truely good welds.
Glenn Neff
Medford, OR
87' 924S
Sleykin
PostPosted: Wed Jul 14, 2004 11:00 am    Post subject: Reply with quote
Sorry about the rant... It's just that I spent more on "cheap" welders etc. than I did on my Porsche. Then I went and spent that much again to get good stuff.
RANT MODE OFF
Glenn Neff
Medford, OR
87' 924S
wdb
PostPosted: Wed Jul 14, 2004 1:24 pm    Post subject: Reply with quote
thanks for the help guys , I know a little about welding and frustration , my welding expierience has been a torch and coat hangers and a little stick . spent more time fixing the holes I made than actually welding anything .
Sleykin
PostPosted: Wed Jul 14, 2004 1:56 pm    Post subject: Reply with quote
Don't get me started on coat hangers & O/A
Too much carbon for a good weld.
Glenn Neff
Medford, OR
87' 924S
PostPosted: Wed Jul 14, 2004 2:24 pm    Post subject: Reply with quote
LOL do it right get a MIG, wirefeed or fluxcore MAY work for sheet metal and exhaust but you are probably going to end up making a few holes, spend the coin and do it right, I have roughly $700 in my welder so far
3 928s,
CBass
PostPosted: Thu Jul 15, 2004 10:45 am    Post subject: Reply with quote
It was a good rant, I agree with everything you said
Except for the OA welding though, I wouldn't want to weld the body of a car with a torch, and I wouldn't recommend it for anyone who is not very experienced with gas welding.
The wire feed is more expensive, but a good MIG welder, even if you run pure C02 , you can still get a good weld, even if you don't have much experience.
The real problem with wire feed is that most people have no idea how to tune the machine in. You have to learn how to recognize how the puddle is reacting, and adjust the wire speed and voltage accordingly. Once you learn that, MIG pretty much just welds itself. You do have to be careful when welding light guage sheet, as it's still not hard to burn a hole, especially around the edges.
If you take the time to learn how to stick weld, that little buzzbox would probably be adequate for your needs. It would probably be much easier to get the wire feeder though, and it has more potential.
The school where I went to for my welding training puts on hobby welding courses every now and then, it's a night class, lasts about two weeks and mostly covers wire feed. You might be able to find a similar program in your neck of the woods.
PostPosted: Thu Jul 15, 2004 2:23 pm    Post subject: Reply with quote
hey cbass you really need to get out here and give me some welding lessons man, oh and the calipers have been taken down and are in excellent condition just need a main seal and boot to complete
3 928s,
