augidog
Posted: Mon Jul 12, 2004 12:51 am Post subject: tire pressure question |
I'm running 205/60/15
Firestone firehawks 44 max psi.
What should the pressure be at front and rear?
I've read a lot of differn't answers and I'm confused .
All highway driving. _________________ 1978 924 95 mile daily driver.
I knew that positive thinking thing wouldn't work. |
Posted: Mon Jul 12, 2004 1:45 am Post subject: Re: tire pressure question |
| Porsche tech specs booklet wrote: | Tire pressures (summer and winter tires) measured with tires cold
924 - front 29 psi, rear 29 psi, spare 32 psi
924 turbo - front 29 psi, rear 36 psi, spare 32 psi |
_________________ "..it's made in Germany. You know the Germans always make good stuff."
Posted: Mon Jul 12, 2004 2:36 am Post subject: |
I always run the tires for what they are rated, if you run them at the 29PSI you will probably get underinflation wear on them, I had run a set of them on my 928 and I ran at 40PSI w/o a problem _________________ 3 928s, |
augidog
Posted: Mon Jul 12, 2004 5:34 am Post subject: |
I used to run 29 psi, then someone said that tire properties have upgraded since the manual was issued.
I also was told not to run full psi because of heat expansion.
Still confused. _________________ 1978 924 95 mile daily driver.
hexen84
Posted: Mon Jul 12, 2004 5:44 am Post subject: |
| I used to work at a tire shop. We filled most tires up to about 35 psi. That way it had room to expand if needed and when it got cold it wouldn't deflat too much. |
Neil924
Posted: Mon Jul 12, 2004 6:26 am Post subject: |
| 35 psi up front and 36 psi in back, on the 03 Grand am. And for the Potenzas on the 924 32 psi front and back {I think} Thr FireStone I have sitting around has a max pressure of 36 psi, so all cars & tires can be different. Check the specs on the tire and then check the weight of the car in the manual. If your tires start wearing in the middle of the tire, you have too much air. If at the sides of the tread, you see chafing, then you don't have enough air. HTH. |
Posted: Mon Jul 12, 2004 6:33 am Post subject: |
I was just going to suggest approx. 35psi all around. That'll give you easier steering and better gas mileage than 29 while still leaving plenty of leeway between under and overinflation. Inflate tires while cold and in the shade and before driving. If you have to drive to an air pump, and want to be real anal about it, put in 36 psi to compensate for the warmed-up tires. Pressures front-to-rear can have some effect on the cars' handling, mainly concerning understeer and oversteer, so go with pressures that you like, but without going to far to either over or underinflation. You can get into all kinds of details like for instance, sidewall flex and if you have different tires front-to-back with different sidewall flex then maybe the flexier ones need more pressure, etc. The best you can do is consider the tradeoffs - gas mileage, turning effort, ride comfort, handling, etc. and go with what you're most comfortable with. _________________ "..it's made in Germany. You know the Germans always make good stuff."
ZV
Posted: Mon Jul 12, 2004 7:56 am Post subject: |
| Lizard wrote: | | I always run the tires for what they are rated, if you run them at the 29PSI you will probably get underinflation wear on them, I had run a set of them on my 928 and I ran at 40PSI w/o a problem |
Should always follow the recommendation from the car's manufacturer. The tires are rated for a maximum pressure to allow them to function on multiple vehicles with different tire loading characteristics. Run the tires at the recommended pressure and adjust in small increments from there to the point where the car feels best and where you're not getting odd wear patterns.
On mu 1987 924S I run 30 PSI front and 34 PSI rear. It makes the car a little more tail-happy than normal and functions nicely at getting rid of the small amount of engineered-in understeer. _________________ Shifting is an art, learn it, love it, live it.
1976 Porsche 914 2.0 - Driving Restoration.
1987 Porsche 924S - Daily Driver |
augidog
Posted: Mon Jul 12, 2004 11:18 am Post subject: Re: tire pressure question |
| Smoothie wrote: | | Porsche tech specs booklet wrote: | Tire pressures (summer and winter tires) measured with tires cold
I went with the specs.
29 psi. thanks smoothie.
Thanks to all
ZV --That was the best explanation I've heard yet to run at standard specs and why tires have a maximum psi. _________________ 1978 924 95 mile daily driver.
ZV
Posted: Mon Jul 12, 2004 12:00 pm Post subject: Re: tire pressure question |
| augidog wrote: | | Smoothie wrote: | | Porsche tech specs booklet wrote: | Tire pressures (summer and winter tires) measured with tires cold
Thanks to all
ZV --That was the best explanation I've heard yet to run at standard specs and why tires have a maximum psi. |
A lot of the higher "Max PSI" ratings on newer tires are just because the carcasses are able to handle those pressures without bursting now, not from any need to run the tires at those pressures.
Running the tires at the sidewall's "Max PSI" without loading the tire near the load limit (also listed on the sidewall, sometimes over 1,500 pounds per tire) will without a doubt cause treadwear issues in the typical overinflation pattern. Note that the "load limit" only applies at that maximum PSI and that as PSI decreases, so does the load limit. So running the tires at the manufacturer's pressure will result in a lower tire load capacity than the maximum sidewall pressure, but as long as the tire's load capacity for the car's GAWR then it's fine, and manufacturers calculate recommended pressure based on the car's GAWRs and desired performance characteristics.
Aaron _________________ Shifting is an art, learn it, love it, live it.
Posted: Mon Jul 12, 2004 12:10 pm Post subject: |
I have found that running the tires below the 32PSI mark causes ALOT more sidewall roll in any of the tires that I have driven on, I do however keep my tire pressure the same front and back, and my cars all seem to break free at the same point front and back (which can get alittle interesting) I do run 225 all the way around _________________ 3 928s, |
-nick
Posted: Tue Jul 13, 2004 12:50 am Post subject: |
I would concur on starting with ~35psi on a ~44psi max rated tire. Our original sticker is for 20+ year old "radial" tires. Rubber has come a LONG way since then!
Same pressures all around seem to work well for me.
-nick |
Posted: Tue Jul 13, 2004 2:16 am Post subject: |
How aggressively and under what conditions do you drive your car? That would offer some insight into which combination of traction, ride comfort and even wear might be most important to you.
FWIW, on the street I run old Pirelli P4000 in 205/60/15 and have run about 34-35psi for years. That seems to give me the best combination of traction, ride comfort and even wear. Other tires in other sizes with different carcass consturution would likely require different pressures to exhibit the same characteristics.
The best way to figure out optimal tire pressures is by putting the car on a track, running a half-dozen laps to get some heat into them, then pyroing the inside, middle and outside of the tread. One would then change alignment and tire pressures accordingy. Another way is to "chalk" the sidewalls to check rollover. Completely impractical for street driving of course. I'd probably pay more attention to ride comfort and even wear for the street.
Also, in the case of the 924 I've always paid more attention to what the tire manufacturer says than what the auto manufacturer recommends and here is why: Tire technology has progressed way beyond anything an engineer might have imagined in the late 70's or early 80's when the Porsche recommendation was created. So, although the factory recommendation was probably the "best" at the time, so much has changed with tire technology that I go with what the tire manufacturer recommends... all IMHO. |
ZV
Posted: Tue Jul 13, 2004 3:07 am Post subject: |
| emoore924 wrote: | | Also, in the case of the 924 I've always paid more attention to what the tire manufacturer says than what the auto manufacturer recommends and here is why: Tire technology has progressed way beyond anything an engineer might have imagined in the late 70's or early 80's when the Porsche recommendation was created. So, although the factory recommendation was probably the "best" at the time, so much has changed with tire technology that I go with what the tire manufacturer recommends... all IMHO. |
I have never seen a tire manufacturer list a "recommended" pressure for any car. Tires list Maximum pressure and load capacity at maximum pressure. The pressure listed on the sidewall is _not_ a "recommendation", it's simply the maximum cold inflation pressure for the tire.
augidog
Posted: Tue Jul 13, 2004 11:52 am Post subject: |
I'm still am finding online that factory specs are a good starting point.
I found this for guys like Lizard who are running tires out of spec from the optional and standard tire sizes.
Do these calculations work on your car?
"In the event that you aren't able to find a recommendation for your car, or the tires on your car are so different from those that were originally fitted from the manufacturer as to be incomparable, we received the following rule of thumb from Oscar Pereda, an engineer for BFGoodrich. He calls it a "realistic starting point," saying it has never been just right, but is a good place to start. The rule is:
(Vehicle Weight in lb/100) + 2 psi at heavier end + 2 psi all around if suspension and alignment are stock.
Example: Stock 911, 3,000 lb.
(3000/100) = 30 psi
Add 2 psi all around = 32 psi
Add 2 psi to heavy end = 34 psi at rear
With modified suspension, the result is 30 psi front, 32 psi rear." _________________ 1978 924 95 mile daily driver.
