924 with v8 ford 292 cubic inch
brit2514
PostPosted: Thu Jun 07, 2007 8:54 am    Post subject: 924 with v8 ford 292 cubic inch Reply with quote
i have just bought a ford v8 from a 1958 galaxie/fairlaine
would this be able to be fitted in a 924
it is a 292 ci with 205bhp (back in 58 of course)
what problems would i have if it would fit?
colin
PostPosted: Thu Jun 21, 2007 8:16 am    Post subject: Reply with quote
the only problem i see is well...everything
1979 924 parting ways
1987 924S
1987 parts car
PostPosted: Thu Jun 21, 2007 8:56 am    Post subject: Reply with quote
I agree. . .and then there's that other thing.
PostPosted: Thu Jun 21, 2007 9:49 am    Post subject: Reply with quote
Well, here's some info on the Engine:
http://en.wikipedia.org/wiki/Ford_Y-block_engine
It is called a Y-block and here is another page about them:
http://www.bacomatic.org/~dw/fordv8/yblock/yblock.htm
Here is a site with some hop-up and performance parts:
http://www.ford-y-block.com/
I'd think you might want to go with a slightly newer V8 with more aftermarket support. That 292 would be great in a hotrod or a rat rod project. Some problems is what bellhousing would you use? Flywheel? Clutch? Motor mounts? Granted these are the same for a 5.0L Ford but the difference is that the 5.0L has a lot more options ready to go while the Y-block might need some parts searched out or custom made from scratch.
Not an impossible project but it may not be a worthwhile investment of your time.
Good luck,
