need help ASAP seems not getting any fuel.
PostPosted: Thu Sep 09, 2004 11:29 am    Post subject: need help ASAP seems not getting any fuel. Reply with quote
Driven on the freeway last nite at dusk all of a sudden my car quites and wouldnt restart I had to have it towed and missed work today what I
discovered though is if I spray starter fluid into the intake then seal it up
itll start right up though wont stay runnen acts like its starved for fuel the tank is topped off full. I removed the fuel line going to the fuel dizzy that comes off the filter and turned on the pump and the ignition not turnen n the motor over though just turning those to on to what I thought should be pressurizing the cis. Well nothin no gas came out ... the fuel pump makes a loud noise like a small compressor being running.. seems like the pumps bad got any ideas anyone can I take the pump apart and find anything to fix...I have extra fuel acc. though no pump could it be the fuel accumulator someone said if you take off the little screw on the bottem of the fuel acc and fuel come out its no good is this true.
PostPosted: Thu Sep 09, 2004 11:45 am    Post subject: Reply with quote
Im trying to get to the end here...I undid the line to the filter and turned everthingon thinking the filter could be clogged still nothing comes out of the fuel line even if I turn the motor over... so.
PostPosted: Thu Sep 09, 2004 11:53 am    Post subject: Reply with quote
Pumps are running but no fuel, are you sure someone didn't steal your gas?
maireeka
PostPosted: Thu Sep 09, 2004 1:34 pm    Post subject: Reply with quote
pump might be broke and still be trying to run, you sure it's actually pumping?
1977 Porsche 924 red and READY!
PostPosted: Thu Sep 09, 2004 2:21 pm    Post subject: Reply with quote
After trying at the dizzy then before the filter and then at the
accumulator then right at the pump to get fuel , Ive come to the
conclusion that the pumps not doin its job. and I cant find any check
balls to prevent back flow heres a pic. Im gonna find another thursday.
PostPosted: Fri Sep 10, 2004 7:28 am    Post subject: Reply with quote
Removed the check ball and spring at the front of the pump still no juice comes through when the pumps turned on...its toast time for a new one.
Heres my new mode of transpo...
PostPosted: Sat Sep 11, 2004 11:21 am    Post subject: Reply with quote
'Well at least I made it back to work today (friday)
without the porsche though.. good thing is work offered time and a half on saterday to work.
maireeka
PostPosted: Sat Sep 11, 2004 1:46 pm    Post subject: Reply with quote
woohoo i was right do i win a prize?!
PostPosted: Sun Sep 12, 2004 3:44 am    Post subject: Reply with quote
Whats your point and Ill tell you about the prize I offer.
maireeka
PostPosted: Sun Sep 12, 2004 8:51 am    Post subject: Reply with quote
my point is just that I'm not too experienced with automotive stuff yet, and I still guessed correctly. grats me on my luck
PostPosted: Sun Sep 12, 2004 10:37 am    Post subject: Reply with quote
Allright today I able to get ahold of a buddy and he told me to come out and take my pick from a box of pumps so I did. Noiw I just got to test them
and find a good they should all be good the other good ones I get from my tests will be up for sale pretty cheap or for trade.
The test is to hook up a pump to my car and run the pump for exactly 30 seconds. A good pump has to deliver 750 cc of gas in that amount of time.
PostPosted: Mon Sep 13, 2004 1:15 pm    Post subject: Reply with quote
Tested all my pumps 2 out of the 4 were good ..bolted the one with the highest out put
on and it started right up.
PostPosted: Sat Sep 25, 2004 4:47 pm    Post subject: Reply with quote
K so I am once again capable of hitting 80-85
through traffic on the freeway like a mini-truck or something.
Leave at 5:30am and get back home about the same time cept
in the pm cars a blast I swear I love it. 80 miles round trip to
work and back..
Anyway after I changed pumps I started to have some sputters
wel I changed out all the cis stuff except the fuel dizzy and accumilator
on my 79 then after doing the filter to know a no-worky situation
I started to think maybe it was the CO and it was Ive adjusted to
lean one time doing it 3 times. I need to time it up with the light
and set the idle up its low I tell ya Im relieved I got to get my pped head to the shop to get shaved though I need to get the special valve spring remover. Hey I bet the shop thats gonna do it has the tool.
Sleykin
PostPosted: Sat Sep 25, 2004 5:02 pm    Post subject: Reply with quote
Bud dit you get yor car runnin?
Glenn Neff
Medford, OR
87' 924S
PostPosted: Sun Sep 26, 2004 1:23 pm    Post subject: Reply with quote
Yea it runs good though the timing is questionable I have a timing light
I just need to know how much adavance to set it with the light. So
does anyone wanna tell me Ill do it sunday. I dont think I ever set the timing correclt with the advance unplugged like your supposed to. I have 3 marks on my dizzy
I made the marks at different times with different set ups so I think its best to I start over. Im usen a actron advance timing analyzer.
http://www.actron.com/product_detail.php?pid=16182
